#276 · date not recorded
well, i had the eec running.
A lightbulb was burning.
No special results to mention on that.
So i played a bit futher...
And then this happend..
#277 ·
what you done there?
i kind of see this happening in the past but it was a cable that were not well contact with the electrode in my case..
#278 ·
i simply squerewaved the cell.
The signal frequency is 3 hz.
The change in amps is way slower going up and down....
So wierd... -
#279 · date not recorded
Sometimes you connect info .......
watch from 39:10
Puharich pulsed slow ...2 a 3 seconds per pulse
To flip protons.
Its very intresting
#280 · date not recorded
Dedicated to Nikola Tesla
All we need is a little more time
I attached the Main Pic from the Start of Thread the Spark plug coils are tesla coils they collapse and
output a cold voltage from centres
NEVER STOP
https://www.hot-rod-usa.com/copy-of-h2-training-guideattachment_16156 TESLA.png
#281 · date not recorded
yes, i still cannot let it go.....
Here are two schematics that are additional to eachother.
I think that the toroid is getting its voltage of two ignitioncoils.
Then you get the tesla coil and the rest...
attachment_16283 attachment_16285 vlcsnap-2021-02-16-19h28m14s656.png anti parallel ignition coils.png
#282 · date not recorded
Nobody? -
#283 · date not recorded
Nobody?
That's an amazing circuit, in it's simplicity. Thanks for posting it; I guarantee I'm going to use it for something. And I have spent some amount of time wondering how to wire up anti-parallel transformers. What's the advantage of doing that? EMI filter, so the MOSFET can keep it's smoke? -
#284 · date not recorded
You simply create double the voltage.
With 20kv coils you get 40kv....
In the case of a Meyer, i might even decouple the secondairys, so you have a totally isolated secondairy circuit.
I know it is possible, but you have yo open the coil casings...
Its a bit of tinkering..
#285 · date not recorded
Moving ahead with this circuit, I ordered a hand full of N channel semiconductors. The ones my supplier had on sale are 200 V @ 20 Amps. So I may try paralleling 2 or 3. Or I can try using a current limiting capacitor on the input to the coils. Or even use a single ignition coil.
Also, a MOT takes quite a bit less than 20 Amps, so I can use the circuit to provide a high frequency environment for the Radiant Energy spark circuit I recently posted.
And I have opened an ignition coil casing before, to remove the core. The hard part was keeping it from leaking afterwards.
And, of course, I always have a variety of other projects I can work on while I'm waiting for the shipment.
