Could this be Meyer's secret?
Started by unknown · · 14 posts · last reply 28 September 2011
I know a lot of people claim to have got workin WFCs but I have not seen one yet.
For those who are still investigating, I have come across a patent that may shine some light on what may be going on.
http://www.google.com/patents/download/13_123_024_METHODS_AND_APPARATUS_TO_CREA.pdf?id=V6XrAQAAEBAJ&output=pdf&sig=ACfU3U2AVZVLOXfDrvLrToOVthI0cuPkWA&source=gbs_overview_r&cad=0
Thanks for posting this very interesting patent !!!
Br,
Webmug -
That is an interesting patent, kind of rides on the stuff that Puharich mentioned in his unpublished book. I'm having trouble following the frequency calculations.
Anyone care to post up how to derive the calculation?
Example from patent: 24/3*2^17 hour = 4.55 hz
I tried doing [24/(3.2^17)]/3600, and it's not close. Not sure what notation the equation is using.
Must be some sort of harmonic calculation or something that I am not understanding -
24/3*2^17 hour = 4.55hz
2^17 = 131072
3*131072 = 393216
24 hour to sec = 24*60*60 = 86400 sec
86400/393216 = 0.21972 --> 1/0.21972 = 4.55111 Hz
Br,
Webmug -
Interesting references with Puharich, Keely... are the harmonics!
24/m*2^n hours, m=1,3,5,7 and 9. What are the values of n ? n=18,17,16,15 ?
Br,
Webmug -
Thank you!
Anyone have a low frequency generator and want to play around with this? Puharich mentions how healers were able to resonate water, and the water would hold it for days/weeks.
Many believe the Egyptians were doing stuff like this with water, the pyramids and their obelisks. Many megalithic sites are built near water, on top of water, etc...
I also heard that Tesla chose his power stations to be near natural aquifers or water or whatnot..... -
Hmmmm, vert intresting, When two oscillators (12 [/font]& 13) are positioned inparallel at a small distance (",,2-100 mm) they automatically
oscillate with 180 degrees phase difference. -
I'm trying to figure out why this patent differs from Puharich's work. It seems like Puharich was dead set on trying to achieve 8 hertz. He talked about how healers produced 8 hertz in their hands, and could charge up water with that.
Some of the statements between the patent and Puharich coincide. For instance, here's a quote from Puharich's unpublished book, page 123:
....and proved that a certain ELF frequency (3.21 hz) will cause cancer. I have repeated these experiments, and found this to be true.
Note that a powerful carcinogen, ethylene dioxide, has coupling constants around 3 to 5 hz. Note that another powerful carcinogen, formaldehyde, has a coupling constant around 41 hz. Parish, et al, have found that the spin-spin coupling constants for water in malignant brain tumors (in humans and dogs) to rang from 4.8 hz to 13.4 hz, whereas normal brain gray matter ranges from 8.6 to 11.3 hz. Thus malignancy shows a spread of frequencies from low to high ELF range ie...with respect to normal brain EEG's, and carcinogens have a wide spread from 3 hz to 41 hz around the center frequency for normalcy of 8 hz. However a single ELF frequency can roduce cancer.
So was this guy measuring differently than Puharich, and thats why the difference (4.55 to 8 hz)?
Maybe I need to study harmonics better. I don't understand like when Puharich was talking about the 7th harmonic of 0.125 hz (= 8 hz).... -
to get the 7th harmonic of 8 Hz it would go something like this:
1st Harmonic: 8 Hz
2nd Harmonic: 8/2 = 4 Hz
3rd Harmonic: 4/2 = 2 Hz
4th Harmonic: 2/2 = 1 Hz
5th Harmonic: 1/2 = 0.5 Hz
6th Harmonic: 0.5/2 = 0.25 Hz
7th Harmonic: 0.25/2 =0.125 Hz -
p197 Puharich: "...Nuclear Magnetic Relaxation cycle of the proton in water. We have found that the characteristic NMR rate, 1/T, in our experiment, is the 3rd subharmonic of 2, i.e. 0,25 secs."
24/3*2^17 = 4.55Hz
2^17 = 131072
(24*60*60) / (3) * 131072 "3rd harmonic"
0.2197 sec !!! ---> 1/0.2197 = 4.5511 Hz
Br,
Webmug -
Hmmmm, vert intresting, When two oscillators (12 & 13) are positioned inparallel at a small distance (",,2-100 mm) they automatically
Thats only if there is much coupling, otherwise any diference in resonant frequencies will creat poins of constructie and destrucie intereferences.. -
8 hz is the schumann frequency. It is known as the frequency that heals.
So, if you want to disturb molecule/atoms, you better look for another frequency.
There is an theory that the human body contains some kind of crystals, who matches the 8 hz....
Thats the reason why the human body can recover when it sleeps.
Just think about the following situation: you go to the beach. Drop a blanket on the sand and you lay down on yr belly.
Why do 9 out of 10 people start getting sleep?
You are very good " grouded" Your body gets into recover mode. Healing mode.
I have seen measurements on that.
But think about it. The human body exists for 80% out of water plus additives. Why does every cell reacts on the 8hz?
Why does the 8 hz tells your cells to get back in the original state?
So, if this is happening, there might be a frequency that does othewise?
Puharich was into medical research. Maybe he found out what part of the water/blood was doing all this.
Hi Steve,
out of interest, physical earthing of the body has been a talk about allowing it to heal, see attached
The website it came from is: http://www.earthing.com
Earthing_book_sample.pdf
Hi Steve,
Nice document. Thank you WFCHOBBY...
