Prostate Cancer At 72 And Home Treatment
Started by unknown · date unknown · 7 posts
PSA number 4 went to 9.6 in 8 months. MRI scan shows cancer 1.2cm. I'm changing diet and integrating cancer home treatment that was known since 1996. Pollutant Nickel taken in goes straight to hair loss and the prostate. All kitchen stainless pots removed and stainless utensils, since SS is composed of alloy with nickel. A knife stuck in salad dressing and then in mouth will show nickel taste in 1/2 second. Don't you remember grandma in the kitchen polishing her SILVER type SILVERWARE? Sandwich spread is made and eaten of Cilantro + olive oil, which is proven to draw out metals from body. The Dr Hulda Clark type mild electrotherapy Zapper kills microorganisms in body to an extent. (about 5-6 volts on+off DC frequency with copper pipe handles through the acupuncture points on hands.)The 3 Dr. Clark herbs also taken by instructions kills the remaining ones in the gut and organs. Contaminated food over time leaves parasites in body. Cancer is 3 things in body same time. - Polluted tissues, microorganisms, and cancer virus. The chemical that is secreted by these parasites just happens to be the growth substance the virus needs to wind up and go. This Orthophosfotyrisine is NOT supposed to be in body- even at minute blood test levels.These microorganisms only have metabolism and thrive WHEN in polluted tissues from propal alcohol absorption. It's in many things we use. Don't give them what they want. Deprive them of their preferred living environment. Also taking Moringa capsules to help reduce PSA number. The cancer will wind itself down to full stop. Read her books- the cure for all cancers, the cure for all diseases. Zappers from Ebay. Purchase orders for Dr. Hulda Clark Store, Inc. -
My dad died 5 years ago because of a “cancer” he was actually killed “euthanasia” because of the pains… ended up I discovered he had a kind of worm called giardia because I started having same pain after he died
My advice is before doing anything take some anti parasites like nitazoxianide, and also something that treats herpes
Other than that I would exercise for the body consume the undesired mass
Drink lot of water
Follow on your risk! This is what I would do to myself!
Best regards
Ps anything you use with dissimilar metals in electrical contact and contact with your skin will insert ions of this metals in you
Electrifying your self is even worst unless you use something like pure platinum and yet that way you will still get little poison any way
Had this years ago. Had mercury fillings removed too
https://en.wikipedia.org/wiki/Chelation_therapy
660nm therapy is effective as a similar heavy metal detox. The metals are ionized, and then attracted out of fat cell crevasses, etc (where white cells can't reach) to attach to red blood cells, and be passed via digestion. -
try my other forum if you need an alternative threatment:
www.cancerhealing.eu
Fenbendazol might be for you.....
Also the Becks device was very helping a friend out with lots of cancer forms...
Age 72 and stage 2 prostate cancer. Currently changing food intake, taking special supplements , removing pollution propyl alcohol intake from products, taking antioxidants , and Moringa capsules, zinc capsules, Using 2 types of electrodes application of Clark Zapper as hands acupuncture points and also between legs. The cellular biologist Dr. Hulda Clark therapy uses the external use Zapper , (on+off 6v DC) while just starting taking the special 3 herbs to eliminate the microorganisms in body responsible for the growth chemical orthophosfotyrasine that keeps the Cancer virus going. The cure for all diseases, The cure for all cancers. Therapy was known since 1995. It's all in the books. Get them. She kept up with patients over time with body tests by the Syncrometer- contamination tester - using microscope slides and the body to detect resonance of RF emissions with samples. Later on, blood tests should show decrease in the PSA number. 4 to 9.6 to a much lower ?? number. MRI scan will then show at that time (if taken) of a benign tumor that can stay in place. Lower maintenance dose weekly thereafter of herbs - Black walnut tincture, cloves, wormwood capsules, to keep stable from that time forward. Alternative therapy. -
Cancer home therapy not working. < russwr > 2024-09-08 11:24
The Dr. Hulda Clark home therapy of 3 herbs has not succeeded. The prostate PSA number has gone up from 8.5 to 12. Only some cancers are caused by micro organisms. The current science research says people have to be on very low carbohydrates/ sugar/glucose, and must do fasting, electrical grounding, and reducing Glutamine by fasting. (Not genetic anymore, it's a metabolic disorder. ) Search data on Earthing/grounding, videos, Build up of electromagnetic volts on body over time period reduces effectiveness of immune system. The immune system knows what to do, but is being HINDERED by these volts on body over time. Your modern synthetic shoes are insulators from our negative ground. Negative electrons flow up wire to wrist strap or to floor plate may help body. Copper pipe tapped into ground outside window and wire brought into house, reduces time having to be outside on open grass with bare feet. I have .032" strip brass bracket on shoe hooked to leg strap. Heel on floor touches copper film and wire, as I type these notes. (Don't use the million ohm resistor in purchased blue wrist strap. The wire end has to be soldered direct to the metal snap. Breathing slightly increases, burning arthritis pain stops, circulation increases because of negative charges from ground, on circulation repels, as same polarity. Multimeter on AC 20 volts range shows volts going to zero after 4 seconds. The body continuously accepts electrons negative flow from ground. Hold red lead in hand, black lead on ground, then touch ground with body to see this yourself.The more time grounded, the better. I also have 2 copper pipe handles to hold while watching the news. Also sleeping with 2nd wrist strap and second wire out window, to second pipe ground. The medical term is now called:-- Nature deficit Disorder.
