Electrical Energy Related Patents
Started by unknown · · 3 posts · last reply 5 February 2025
A US Patent issued costs thousands of dollars by the applicant. It contains data and electrical schematic of GENERALIZATION only.The whole and accurate wiring lines hook ups are never there, except for the Horvath Patent- which has 1 1/2 pages proofreading errors only. The claims list involved never states over unity or free energy. If highly interested, you have to do research on the applicants involved and see their manuscript and related technical data, FOR THEIR CLAIMS, not put in the original Patent application.There is usually some data available.
As for example the Jackson Water Burner was Patent about high pressure 90lbs, high temperature 1500 degrees steam through tiny oil nozzle to ambient air that transforms to hydrogen torch in highly insulated oil furnace chamber. What wasn't noted in Patent, was that magnetic field poles must be involved, pulling on the highly agitated, volatile,water molecules electron orbitals to change the angle in degrees on H and H to the Oxygen atom . (more vulnerable to separation.) I read most of their manuscript. The US soldiers from 1950, furnace running on water line 100%, after starting on oil, received only stated in Patent as 50% allowed increase in efficiency.
Same thing with the Hydrostar Patent by Chambers. The included schematic does NOT SHOW wiring of the available high voltage back EMF from wire inductor coil, to be applied to the electrode SS pipes in water cell. Patent reference was only 25% increase in efficiency allowed. The ONLY ALLOWED build parts manual ended with same only. He had earlier worked for Meyer of Water Fuel Cell in Ohio, and was fully aware of Meyer's work of over unity Hydrogen generator called Voltrolysis. Meyer's Patents time have ran out and are in public domain. Others are attempting to build his cell. -
If anyone wants to build the Horvath circuit as it is, good luck https://patents.google.com/patent/US4107008A/en
TR1 is supposed to be push-pull with Z trigger coil. -
Likewise horvath uses magnetic fields but it’s there to be able to use Lorentz force and by consequence able to generate electricity from water movement
The movement under resonance is amplified by the continuous and systematic application of the electric power up to the point where it generates a voltage on water that when “extracted” generate electricity back and gas as by product
The efficiency come from it developing the voltage on water by resonance while the electricity cycled back
Voltage is not consumed if is perpendicular to the direction of the conventional current flow in the circuit given by the movement of the water this perpendicular voltage increases and split the molecule and so the charge just need to be neutralized so it can get the gas to form
The key in generating energy is how you will consume it and Stan come and say well I need to do this to make the gas be generated and the key is that at same time it generate electrical power 100 amps discharge and he derive the voltage of 100v from a 1 ohm resistance of course that the circuit need to have
He later says we’ don’t really want to stabilize so he increase this resistance (flash lamp) where not only he forces the discharge to happen at a higher voltage but also irradiate the water with this infrareds and ultraviolets that give a ffurther boost on the voltage dissociation effect
Energy can be converted from one form to another! Sound to electricity or heat or pressure or particles velocity
Particles velocity in perpendicular motion to a magnetic field generate a voltage
When you put voltage you accelerate the molecules if they cross a magnetic field they have a voltage that is perpendicular to its polarization
Might be present to you how induction cooking can induce a high current on metals
Well it does on water as well at a specific frequency and conditions and geometry
A magnet spinning in a coil is an example of what happens with the water electrons
Good luck you all
