Stan Meyer effect ?
Started by unknown · · 17 posts
    I just read the following.
    Its interesting enough to publish:
    http://sci.tech-archive.net/Archive/sci.physics/2008-04/msg02346.html
    I ran some experiments today using pulsed frequency with a tube electrolyze
    similar to the Stan Meyer's. I believe he was a fraud and still do but some
    interesting things were observed in a controlled experiment using tap water.
    Note that I have current limited the supply with a resistor. The max draw
    is 4.3 amps possible.
    With the cell connected directly I was pulling 4.3 amps.
    Gas production is 60 CC.
    I devised a simple mosfet pulsed circuit using a signal generator
    The cell produced peak flow
    at 40 CC with a draw of 2.85 amps /30 volts at about 16 KHZ. That seems to
    be the best range. The scope reads about 45 volts peak to peak.
    Now something interesting occurs when I add a large iron core copper choke.
    The current draw goes down to 2.51 amps and it produces a steady 68 CC
    of gas. The scope climbs to 78 volt's PP. This would suggest that back EFM
    is playing some role in the dissociation. Conventional theory suggest that
    only current can play a role. This would seem to debunk that. I am very
    confedent with my numbers but I have
    no clue what they mean. The less current drawn and the more gas output the
    more the mosfet heats up and I would expect that.
    I think Meyers was on to something but far from running your car on water
    of course. This expierment did open my eye's on how stan could have fooled
    people. There is a visual increase of gas output that looks like an order of
    magnatude. Note that I said Looks like. ;o)
    continue:
    The first question to be answered is how are you measuring the current
    and voltage and what is the accuracy with the given frequency and
    waveform?
    Peak to peak voltage is meaningless without other information.
    Jim Pennino
    Remove .spam.sux to reply.
    Jim, I am using a Fluke RMS current meter. It is not fooled by high
    frequency pulses
    However at 16 KHz a typical current shunt will not be effected that much at
    all.
    As fas as the shunt is concerned it's seing DC. Your right. Voltage is
    suppose to be meaningless with electrolysis. It's the current. The supply
    is regulated to 30 volts. The point is current went down and gas production
    went up and the voltage drop across the resistor confirms I am pulling less
    current.. The supply will not put out more the 30 volts so the 80 volt PP
    has to be back EMF from the coil. Remember I am current limited. Even with
    max current 4.3 amps it's still less gas then with the pulse and choke. So
    even if I was really drawing 4.3 with the choke and pulse curcut it can't
    pull more then 4.3 amps through the resistor. I should note that the choke
    is in series with the cell. It appears there is some interaction with the
    cell as part of circut and is indeed acting like capacitor. I am not your
    typical youtube idiot. I am 100% confedent in my observations. I don't
    however claim to know what it means. All this happens real time.
    If I dial the frequency to far one way or other the gas production goes down
    and tracks current. Another reason I am confedent with my measurments.
    I have a theory that the pulses and back EMF is simply rasing the volatge
    potential between the cell plates some how? It takes current to do that but
    in this case less current.
    continue:
    True-RMS meters can handle non-sin waveforms but the errors can be large,
    particularly if the waveform isn't symetrical about the zero axis. Your
    circuit has a single FET and single voltage rail so I suspect the waveform
    isn't symetrical about zero (more like half the supply voltage).
    There are lots of ways to improve the efficiency of the electrolysis process
    but no way to exceed 100%. Wikipedia reports 80% and a prediction that 94%
    might be achievable.
    Note from another site:
    In an electrochemical reaction (electrolysis of water for example), a back emf is produced when the reaction components (like hydrogen and oxygen) try to recombine and produce a voltage which opposes the forward emf which is causing the electrolysis.
  5. Dankie
    This quote makes me think this is the Meyers effect .
    "It is this ringing that also enhances the production of hydroxl gases in cell ."
    What ringing ? How do you adjust anything when all is done ?
    Pay attention and listen  . DO NOT IGNORE THE PARTS YOU DONT UNDERSTAND .
  6. haithar
    Just like the normal theory, his chokes limit current while inducing a voltage spike, so he has more voltage less current with the same power, current limiting via coils isn't new (http://en.wikipedia.org/wiki/Electrical_ballast).
    I'd think the back emf is just like in meyers document, when the pulse stops it creates another pulse and doubles the frequency.
    Haithar,
    Yes, you are right.
    But WHY does the watercell produce more gas with higher voltage and less amps?
    Is it because the Bemf shoots in a lot of Joules (read amps) in a short boost?
  8. Dankie
    Stevie , I think sometimes you are just running around in circles , did you even make that GEET working ?
    There is no magic magic way to connect a randomly made choke and the "BEMF" super spikes do the work . There is a whole tuning aspect here , and these inductive spikes are just a part of it .
    Dankie, if you wanna know how my geet project is going, then go to my geet project.
    About my question: did you understand the question?
  10. Dankie
    You question , or your views , ressemble the oversimplified views of sebosfato
    Why when people try it , it doesnt work . Because it doesnt work simple like BEMF that you or Hydro can make with a "secret connection" or a "high-amps" discharge ... Those are all easy answers ...
    What about impedance matching ? What about tuning your source to your cell .
  11. outlawstc
    how about you explain your ideas of why impeadance matching is so relative to your thoughts as being the missing link... make the visual connection instead of just repeating the subject impedance matching is the useen issue..
  12. Dankie
    Well first of all , you gotta know what exactly impedance and reactance is . Then you must read the puharich papers and Hydroxyl paper , and when you ask yourself the question of why exactly is Stan leaving calculations and formulas , those were not therefor nothing if anything goes .
    And when you actually start studying RF and electricity , instead of trying to find "visual" representations of what impedance is on youtube and trying t "imagine" impedance...
    And when you realise that your source and load will be mismatched right from the start unless it has been pre-calculated aka "tuned bobbins and cell" , either that or you have an impedance matching circuit .
    When you reach that point you can start seeing a "visual connection" , untill then , it will be impossible to even dream about it in your sleep .
  13. haithar
    so i assume you got it working now dankie?
  14. Donaldwfc
    he's way ahead of us
  15. Alan
    Xc must be smaller than Xl, so it's an impedance mismatch between chokes and wfc, agree? But this is also frequency dependent.
    Bt why are they matched early on in the brief?
    RF occurs as spikes during the edges (puharich).
    And still, reflection (RF spikes reflected back from wfc to chokes) keeps entering my mind.  :P
    Voltage is seen then, but no power is absorbed by wfc.
    something like that, forgot it a bit because of the twisted stuff lately.
  16. Dankie
    I am actually the first ever , in the entire world , who is making this the way its supposed to be done , or at least trying too .
    Past simply putting bobbins and cell together and praying . I hope my method will show results , my methodology is certainly more time efficient and '' dummy proof '' and more 'tunable'
    I dont have or need a fancy education , I just do it .
  17. Steve
    Alan is right, Dankie.
    Do you know what happens if you use a pulsing circuit on a WFC in the water?
