Patents and official documents of Stanley Meyer
Started by unknown · · 14 posts · last reply 26 March 2017
    Here are all Patents of Stanley Meyer and other official released documents.
     CA1213671A1 Electrical Particle Generator.pdf  CA1227094A1 Hydrogen Air & Non-Combustible Gas Mixing Combustion System.pdf  CA1228833A1 Gas Electrical Hydrogen Generator.pdf  CA1231872A1 Hydrogen Injection System.pdf  CA1233379A1 Hydrogen Gas Injection for Internal Combustion Engine.pdf  CA1234773A1-Resonant_Cavity_Hydrogen_Generator_That_Operates_with_a_Pulsed_Voltage_Electrical_Potential.pdf  CA1234774A1-Hydrogen_Generator_System.pdf  CA1235669A1-Controlled_Hydrogen_Gas_Flame.pdf  CA2067735A1-Water_Fuel_Injection_System.pdf  EP0086439 Hydrogen Gas Injection System for Internal Combustion Engine.pdf  EP0086439A1-Hydrogen_Gas_Injection_System_for_Internal_Combustion_Engine.pdf  EP0086439B1-Hydrogen_Gas_Injection_System_for_Internal_Combustion_Engine.pdf  EP0098897 Electrical Generator Utilizing Magnetized Particles.pdf  EP0098897A2-Electrical_Generator_Utilizing_Magnetized_Particles.pdf  EP0098897A3-Electrical_Generator_Utilizing_Magnetized_Particles.pdf  EP0101761 Controlled Hydrogen Gas Flame.pdf  EP0101761A2-Controlled_Hydrogen_Gas_Flame.pdf  EP0101761A3-Controlled_Hydrogen_Gas_Flame.pdf  EP0101761B1-Controlled_Hydrogen_Gas_Flame.pdf  EP0103656 Resonant Cavity for a Hydrogen Generator.pdf  EP0103656A2-Resonant_Cavity_for_a_Hydrogen_Generator.pdf  EP0103656A3-Resonant_Cavity_for_a_Hydrogen_Generator.pdf  EP0106917 Gas Electrical Hydrogen Generator.pdf  EP0106917A1-Gas_Electrical_Hydrogen_Generator.pdf  EP0111573 Hydrogen Generator System.pdf  EP0111573A1-Hydrogen_Generator_System.pdf  EP0111574 Hydrogen Aeration Injection System.pdf  EP0111574A1-Hydrogen_Aeration_Injection_System.pdf  EP0111574B1-Hydrogen_Aeration_Injection_System.pdf  EP0122472 Hydrogen Aeration Injection System.pdf  EP0122472A2-Hydrogen_Aeration_Injection_System.pdf  EP0122472A3-Hydrogen_Aeration_Injection_System.pdf  EP0333854A4-Hydrogen_Aeration_Injection_System.pdf  EP0381722 Hydrogen Aeration Injection System.pdf  EP0381722A4-Hydrogen_Aeration_Injection_System.pdf  Independant test document.pdf  JP58202352A.pdf  JP58207610A.pdf  JP59038525A.pdf  JP59059889A.pdf  JP59129791A.pdf  JP59132784A.pdf  JP59148584A.pdf  JP59153922A.pdf  The Birth of New Technology - S.Meyer.pdf  US3970070 Solar heating system.pdf  US4265224 Multistage solar storage system.pdf  US4275950 Light Guide Lens.pdf  US4389981 Controlled Process For The Production Of Thermal Energy From Gases.pdf  US4421474 Hydrogen Gas Burner.pdf  US4465455 Startup Shutdown For A Hydrogen Gas Burner.pdf  US4613304 Electrical Hydrogen Generator.pdf  US4613779 Electrical Pulse Generator.pdf  US4798661 Gas Generator Voltage Control Circuit.pdf  US4826581 Controlled Process For The Production Of Thermal Energy From Gases.pdf  US4936961 Method For The Production Of A Fuel Gas.pdf  US5149407 Process & Apparatus For The Production Of Fuel Gas.pdf  US5293857 Hydrogen gas fuel and management system for an internal combustion engine.pdf  US6419815 Method for producing orthohydrogen.pdf  WFC News letters No 3.pdf  WFC News letters No 4.pdf  WFC News Letters No 8.pdf  WFC News Letters No 10.pdf  WFC News letters No 11a.pdf  WO8901464A3-Controlled_Process_for_the_Production_of_Thermal_Energy_from_Gases_and_Apparatus_Useful_Therefor.pdf  WO1989001464 CONTROLLED PROCESS FOR THE PRODUCTION OF THERMAL ENERGY FROM GASES.txt  WO1989001464A2 CONTROLLED PROCESS FOR THE PRODUCTION OF THERMAL ENERGY FROM GASES.pdf  WO1989012704A1 PROCESS AND APPARATUS FOR THE PRODUCTION OF FUEL GAS AND THE ENHANCED RELEASE OF THERMAL ENERGY FROM SUCH GAS.pdf  WO1992007861A1 CONTROL AND DRIVER CIRCUITS FOR A HYDROGEN GAS FUEL PRODUCING CELL.pdf  WO1992008046A1 HYDROGEN GAS FUEL AND MANAGEMENT SYSTEM FOR AN INTERNAL COMBUSTION ENGINE UTILIZING HYDROGEN GAS FUEL.pdf  WO1992022679 An injector system comprising an improved method and apparatus.txt  WO1992022679A1 An injector system comprising an improved method and apparatus.pdf  memo+wfc+427.pdf
    Thanks Steve, Re-reading once again...
    LOL...i did too.....for the 1000th time....
    I found again a piece that got my attention...
  4. sebosfato
    Me too! Its very suspicious the subtle changes in the text!
    Release atomic energy under controlled state by applying electric fields. wow
    Makes lot of sense for me, the physicists don't see this, they can only see a chain reaction neutrons and ever lasting radiation...
    for me is clean
    This is what is keeping my mind tickeling. First Stans text. Then the text after deleting lots of crap talk:
    First water mist (47) of Figure (4-4) is injected into fuel-mixing chamber (35) of Figure (45) by way of
    water spray ports (41a xxx 41n) of Figure (4-4); Secondly, ionized air gases (46a xxx 46n) of Figure (4-
    4) (laser primed ambient air gases having missing electrons) produced by Ambient Air Ionizer (80) of
    Figure (4-6) as to Figure (4-1) and non-combustible gases (45) of Figure (4-4) are intermixed with
    expelling water mist (47a xxx47n) to form Water-fuel mixture (48) by way of gas mixing disc (34) of
    Figure (4-5) as to (30) of Figure (4-2); thirdly, the resultant moving Water-Fuel mixture (48) of Figure
    (4-5) enters into Voltage Igniter Stage (180) of Figure (4-5) and exposed to hjgh intensity voltage fields
    (33/36) (typically 2,000 volts or above @ 10 Khz or above) of opposite electrical polarity (E7 / E8) ...
    which, in turn, not only performs electrical polarization process (160) of Figure (3-26) undergoing
    Dielectric Resonant (240) of Figure (3-31); but, also, sets up and triggers Hydrogen Fracturing Process
    (390) of Figure (3-42) as to Figure (3-6) under control state (on demand) via electrical-static spark
    ignition (49/51) of Figure (4-5) .... releasing thermal explosive energy (gtnt) (16) passing beyond gas
    exit port (32) of Figure (4-5), as further illustrated in Figure (4-2) as to Figure (4-1).
    First water mist is injected into fuel-mixing chamber.
    Secondly, use ionized air produced by Ambient Air Ionizer.
    Third, add as option exhaust gasses = watervapour, if it runs on water
    Fourth: use a plasma sparkplug system
    Long story short. I must add a startermotor on my generator........then i can go run tests with ionizers, watermist and plasma sparks...
    After all these years, i finally got some original manuals of Meyer....
    I will scan these in januari and share them with you all... :)
    Merry Christmas!!! HHOHHOHHOHHOHHO  ;D
    attachment_12145 attachment_12147 attachment_12149 attachment_12151 attachment_12153 attachment_12155 foto-7.JPG foto-8.JPG foto-9.JPG foto-10.JPG foto-11.JPG foto-12.JPG
  7. geenee
    Steve,you are the Great man!!!
    Blessing
    geenee
  8. Newguy
    cant remember seeing this one
  9. jim miller
    The manuals and documents of Stanley A Meyer, when posted at Ionizationx,  will not only preserve
    the written legacy of  a truly remarkable person but also serve as a standard to compare with other
    copies of  his work. New scans of the photographic images will have slightly different gammas which
    bring out details not visible in previous scans. For serious experimenters, archivists and photogrammetric
    enthusiasts,  this is a remarkable find that Steve at ionizationx is sharing with the HHO community.
  10. Steve
    You are welcome, Jim.
    I have two versions of the sales manual and there are some differences. I looked them thru paga by page..
    It is strange to have them here in my hands...
    Also the info brochure number 6 and the tech manual are much better to read, somehow.
    I will create some pdf's of them.
  11. webmug
    This is good work, Steve  :)
    Cheers!!!
    Br,
    Webmug
  12. Steve
    the dealer manual!
     Stan Meyer Dealership Sales Manual 1986 OCR CONVERTED.pdf
  13. scarou
    Nice work, thanks a lot Steve !
    I have done a similar work this Stanley MEYER's patents (cleaned scanned documents and making an OCR of the text) in order to be able to make keywords searches on all documents. I will add this one in my dedicated search folder !
    (I will make a new post to share my work too.)
    http://www.ionizationx.com/index.php?topic=3183.msg30476#msg30476
  14. jim miller
    Stanley Meyer Autopsy Report posted at ionizationx.com
