New DC resonant charging circuit
Started by unknown · · 18 posts · last reply 12 April 2010
    Here is a working DC resonant charging circuit.
    The voltage across the Waterfuelcell is al least twice of the input voltage.
    In my case almost 30Vpp against a 10v input.
    You might pull the conclusion that the waterfuelcell acts like a small battery or capacitor.
    Tune the circuit till you reach the highest voltage across the waterfuelcell.
    USE ONLY TABWATER OR DESTILLED. NO CHEMICALS ALLOWED IN HERE.
    Type of diode: Not important. Only heavy enough for the amps you use
    Type of coil: in my case 25 winding of 1mm wire on a metal lamel core. 1mH
                        Just play with some cores you have.
    Type of FET: Not important. Any N type will do. The lower the internal resistance the better. Your choice depends on voltage and amps.
    Frequency: try to stay above 1khz with tuning. My test was done around 10khz.
    http://www.tpub.com/content/armymunitions/mm50058/mm500580088.htm
    http://www.richieburnett.co.uk/dcreschg.html#resonant
    http://teslahv.com/DC%20Resonant.htm
  2. haithar
    how would you integrate the step-up transformer into this circuit?
    the only way i can think of is using a hv-mosfet. not the best idea
    Tesla used for this a rotary switch.
    Like the distributor from a cars ignition system.
    Stan solved that somehow with pulsing the stepup trafo..
  4. handyandy
    That is the conclusion I recently reached regarding Stan's circuit.  His inspiration was Tesla's method of conversion of high potential and frequency and Stan modified it slightly so the path was unidirectional.  Before the rotary switch there was the spark gap and then Tesla would quench the spark magnetically or by air or otherwise.  Stan uses the 555 and divide by 8 or 10 counters to simulate the rotary switch in solid state.  IF there's communication between the wfc and the vic then it's the pickup coil that's the "antenna" for feedback to the front end.  I don't see much difference between what Stan was doing and what Tesla was studying and publishing and patenting.  The difference is where Stan publishes the location of some components like the scr.  The front end should get a nice sine wave and the back end should switch on and off very fast.  If I want 50% duty cycle I would use ac like a center tap transformer, a half wave bridge and 2 or a multiple of 2 tubes or tube arrays.  For 3 phase a multiple of 3 tubes.  It's as simple or as complicated as one wants to make it.
    Andy
  5. haithar
    But back to the circuit,
    why does it work fine in this configuration (switch/mosfet parallel with cap) - i can get 70V at the capacitor from 30V at 0,1A - but why doesn't it work in the stanley meyer / richie burnett / tesla coil version at all? (same voltage but only 2V at the cap).
  6. haithar
    btw you can get voltage to your water cell which is not insulated with this method!! Strangely enough i had to change the direction of the bifilar connections yet again.
    unfortunately the amp draw in general is too big so i cannot test further yet. i'm also thinking of rectifying my 230V grid current which would give me about 350V DC i believe. I have a switching Mosfet for 600V so it would work. But the current is way too big at the moment.
  7. Donaldwfc
    add a series resistor some where? might need a big one though
  8. haithar
    but it will eat up the voltage, even a 20Ohm. I don't know why the coil uses so much current even when pulsed at 50kHz. I think i have a short in the circuit somewhere or something like that.
    a coil perhaps as resistor?
  10. haithar
    Why is it that current goes up dramatically if i put a flyback diode anti-parallel to the coil in this circuit?
    Same is when i put a diode parallel to the transformer, the current isn't frequency dependant anymore, without diode: 30V / 0,3A. with diode: 3V / 1A (1A limit from power supply). i don't get it.
    anyway, problem solved. without the diode current draw is small.
  11. Steve
    here a new Stan based setup.
    The voltage across the cap charges higher then applied voltage.
    The resistor is for leaking charge, but cannot simulate a WFC perfectly...
    Cap and coil and frequency match.
    The result is that amps and volts are 180 degree out of phase.
    Hmmm, who said that his system was working with 180 degrees phase difference between volts and amps?
    yes STAN MEYER...
    $ 1 5.0E-6 0.23009758908928252 51 5.0 50
    c 416 240 416 320 0 1.0E-8 21.46768997989414
    r 480 240 480 320 0 3806.0
    w 208 320 320 320 0
    w 416 240 480 240 0
    w 416 320 480 320 0
    d 208 240 240 240 1 0.805904783
    l 240 240 288 240 0 0.01 -1.2134390714457766E-15
    w 320 320 416 320 0
    w 288 240 416 240 0
    v 144 320 144 240 0 0 40.0 36.0 0.0 0.0 0.5
    w 144 320 208 320 0
    159 208 240 144 240 0
    R 176 224 176 128 0 2 15500.0 5.0 0.0 0.0 0.5
    o 0 1 0 35 61.23604138321678 0.03827252586451049 0 -1
    o 9 1 0 35 40.0 0.1 1 -1
    o 1 1 0 35 69.99202319305638 0.02187250724783012 2 -1
  12. haithar
    Why does it work in a simulation but not in reality  :-\
    c 416 240 416 320 0 1.0E-8 700.655449046733
    w 416 240 480 240 0
    w 416 320 480 320 0
    l 240 240 288 240 0 0.01 -1.3877787807814457E-17
    w 320 320 416 320 0
    w 288 240 416 240 0
    v 144 320 144 240 0 0 40.0 360.0 0.0 0.0 0.5
    w 144 320 208 320 0
    R 176 224 176 128 0 2 3000.0 5.0 0.0 0.0 0.5
    w 208 320 320 320 0
    o 0 1 0 35 979.7766621314685 7.475102707912206E-5 0 -1
    o 7 1 0 35 640.0 9.765625E-5 1 -1
  13. Steve
    w 416 240 480 240 0
    w 416 320 480 320 0
    w 320 320 416 320 0
    w 288 240 416 240 0
    w 144 320 208 320 0
    w 208 320 320 320 0
    I hope to give it a shot this week...
  14. Hydrocars
    c 416 224 416 304 0 1.0E-8 -1.2675553006208302
    w 416 224 480 224 0
    w 416 304 480 304 0
    d 208 224 240 224 1 0.805904783
    l 240 224 288 224 0 0.01 -1.7763568394002505E-15
    w 320 304 416 304 0
    w 288 224 416 224 0
    v 144 304 144 224 0 0 40.0 360.0 0.0 0.0 0.5
    w 144 304 208 304 0
    159 208 224 144 224 0
    R 176 208 176 112 0 2 3000.0 5.0 0.0 0.0 0.5
    w 208 304 320 304 0
    A 144 304 48 256 0 0 40.0 5.0 0.0 0.0 0.5
    g 416 224 416 128 0
    o 0 1 0 35 979.7766621314685 4.898883310657343 0 -1
  15. Steve
    w 416 224 480 224 0
    w 416 304 480 304 0
    w 320 304 416 304 0
    w 288 224 416 224 0
    w 144 304 208 304 0
    w 208 304 320 304 0
    g 416 224 416 128 0
    Brian,
    You added an Antenna towards your schematic.
    Can you explain why you did this?
  16. Hydrocars
    $ 1 5.0E-6 2.922428378123494 57 5.0 50
    T 224 224 288 224 0 1.0 20.0 85.16743026114969 -4.253913238796301
    R 224 224 128 224 1 5 1000.0 12.5 2.5 0.0 0.5
    g 224 256 224 288 0
    d 288 224 320 224 1 2.0
    w 320 224 368 224 0
    l 288 256 368 256 0 1.0E-6 -19152.689663265097
    w 368 224 400 224 0
    w 400 224 432 224 0
    w 368 256 400 256 0
    w 400 256 432 256 0
    c 400 224 400 256 0 0.0010 172.38628755085708
    r 432 256 432 224 0 78.8
    w 432 256 480 256 0
    w 432 224 480 224 0
    i 480 256 480 224 0 0.0050
    g 288 256 288 288 0
    A 400 224 400 144 0 0 40.0 5.0 0.0 0.0 0.5
    o 10 32 0 43 1197.2621413014756 24519.928653854222 0 -1
  17. haithar
    233A in?  :-\
  18. Hydrocars
    233A in?  :-\
    T 192 224 256 224 0 1.0E-7 15.0 51889.26488604761 -3527.0557713618805
    d 256 224 288 224 1 2.0
    w 288 224 336 224 0
    l 256 256 336 256 0 1.0E-6 -116.77937902392864
    w 336 224 368 224 0
    w 368 224 400 224 0
    w 336 256 368 256 0
    w 368 256 400 256 0
    c 368 224 368 256 0 0.0010 -11.666537336615782
    r 400 256 400 224 0 78.8
    w 400 256 448 256 0
    w 400 224 448 224 0
    i 448 256 448 224 0 0.0050
    g 256 256 256 288 0
    A 368 224 368 144 0 0 40.0 5.0 0.0 0.0 0.5
    w 192 256 160 256 0
    w 192 224 160 224 0
    162 160 224 160 256 1 0.5 1.0 0.0 0.0
    162 192 256 192 224 1 0.5 1.0 0.0 0.0
    o 12 64 0 35 160.0 0.05 0 -1
