Magnetic field vs ortho and para hydrogen in relation to running engines on hho
Started by unknown · · 13 posts · last reply 3 November 2011
    Hydrogen exists in two different isomertic forms: para- and ortho-. At room temperature 75% of hydrogen is in the para (i.e. stable) form. In the fifties an American rocket scientist, Simon Ruskin, realized that parahydrogen could be converted to higher energized orthohydrogen through magnetic stimulation, i.e. the application of the proper magnetic field to change the spin state of the hydrogen molecule, as currently is done by the MAGNETIZER, which considerably enhances the energy of the atom and the general fuel reactivity, i.e. the combustion efficiency.
    As a matter of fact Ruskin was granted the U.S. Utility Patent no. 328,868 for this discovery.
    The hydrocarbon fuel of space-shuttle is subjected to the influence of the magnetic field, in order to change the isomeric form of hydrogen from parahydrogen into the orthohydrogen state.
    At the lift-off the orthohydrogen (more reactive form) allows to intensify the combustion processes.
    Without the MAGNETIZER type of technologii Columbia space-shuttle could not lift-off.
  2. webmug
    So they use a lot of current instead of voltage. 8)
    br,
    webmug
    Hmmmm,
    I wonderd always what they mean with ortho or para.
    I do now remember two sorts of gasoutput. Not that i was able to measure the content, but some hho output  was cold, misty and it wasnt watervapour. Propably it was para converted i to ortho and thats why it coold down......
    When ortho converts back into para, it will release a lot of heat!
  5. sebosfato
    Steve, it related to the direction of the electron pair spin. If both are in the same direction the molecule become magnetic. Paramagnetic i guess.
    Interesting thread.
    For one, when hydroxy gas is generated, the surface it is generated from has an impact upon the gas at generation. So it is not simply a matter of the gas having to pass through CrO3 for conversion after generation.
    If that surface has been prepared to be comprised of predominantly detrimental CrO3, then the hydrogen that evolves from that surface will be predominantly parahydrogen. This has been measured and verified.
    If that surface has been prepared to be comprised of a predominantly beneficial material, then the hydrogen that evolves from that surface will be predominantly orthohydrogen. This has been measured and verified.
    As you stated, hydrogen will seek equalibrium, so the ratio will change over time. The fresh gas is what we are interested in, as we do not intend to store the gas prior to use.
    At the time of the HHO Games, I was not aware that there was a fairly simple lab procedure that could be used to measure the ratio of orthohydrogen to parahydrogen. That has since changed. Prior to me leaving florida, labs were just too expensive for me to pay for lab time myself, and Bob Potchen would not pay the price either.
    The group I have been working with since then is doing all of the lab work required to prove out and document this technology. The results of their investment is their property, so it may be some time before they are ready to publish all of their findings, if they decide to do so. I have to clear each and every disclosure I intend to make, before I can.
    Lab testing has also proven that it is the reactivity of orthohydrogen that is responsible for the increased combuston efficiency that we see in the combustion of complex hydrocarbon fuel chains. I suspected this for a very long time, and had confirmed for myself with gas quality vs performance testing. But I did not have scientific evidence to confirm it before. It made perfect sense to me, looking back on past research and experiments. Also, I can see that the results of the NASA hydrogen boosting study are a confirmation of this. The tank hydrogen used in that study was obtained from liquid hydrogen stores, and was still very low in orthohydrogen ratio. The hydrogen from the natural gas reformer contained a higher ratio of orthohydrogen. They could not explain the reason back then, as they did not know. But it was good that they included that information in the study. Interesting how the results of such an old study can be so important, once the importance of the variables involved are known.
    Bob Boyce
    Thank you.........
    Lets skype soon, Fabio.
    It has been too long ago.
  8. wfchobby
    attempt at post number 4
    when posts contain legitimate url's, the post may come up blank and u lose all of your written post, so if youre to include a url that may not be 100% properly formed, copy your post b4 replying.
    when googling the ruskin patent number, also found a site that has magnet kits for the fuel, air and water on engines, http://www.wholly-water.com/MagnetizerAuto.htm
    a thought,can magnets be aligned to help with electron ejection as part of a process like or similar to the meyers air processor?
  9. Bubz
    Bob Boyce? Why doesn't he register to reply? I'd like to see him post here more often...
  10. Steve
    Its an old quote from Bob that i copied....
    We had Bob here some years ago..
    Not sure if he still reads up..
  11. Bubz
    OK! I got it! Thank you for pointing that out. I was confused for a bit, until I saw Bob's name at the bottom. I was starting to wonder what you and Potchen had going on and the words didn't seem like your normal writing style. Thanks Steve!
  12. Evanyoung
    More info. and research is needed into this particular field so as to be implemented in the common mans day-to-day life.
  13. sebosfato
    This indicates the magnetic potential energy of hydrogen atom.
    When an atom receives energy from a fixed hv photon, it will only raise its energy level to a certain point. However if you apply a magnetic field specially a varying magnetic field, like inside a resonant coil, you create different levels of absorption of photon energy. This could makes the electrons to goes to outer orbits and finally ejects... Maybe electric fields also makes the same thing.
    The water form a double layer with electrodes 10 angstrons thick where 0,5 volts is distributed forming an electric field of 5 Million Volts/cm at each electrode in contact with water. This is basic electrochemistry of fuel cells. see double layer. The big problem is that this electric field is in counter action with the applied field and is the reason for many of the kinetic limitations of the electrode water interface.
     Arquivo Comprimido.zip
