In-car timing adjuster
Started by unknown · · 12 posts · last reply 16 June 2008
This is so bad ass. I dont know why, but I like it so much. Its way cool to be able to change the timing while the engine is running from inside the car.
(http://www.rpmcat.com/images/8680-M46.jpg) -
Very nice, CN!
Br
Yes, it's very cool.
Please forward the link that it may purchased from.
Thanks Steve. -
Here we go, was able to run down the link for the timing module.
http://www.shopatron.com/product/product_id=MSD8680/424.0
Enjoy -
here is a link to summit's online catalog, for MSD timing adjusters, http://store.summitracing.com/egnsearch.asp?N=400122+301083+115&autoview=sku
check out any of the major speed equipment suppliers for MSD stuff. -
Guys you need to retard ur ignition and not advancing it, MSD hawe timing adjuster for retarding too, then again there is no problem doing this manualy
I found 0 deg. to 5 deg. after TDC to be good (this is not cham shaft angle guys)
Static ignition timing works good if you just runing H2+HHO, set it to around 0 deg and that is it
Mr Brown/H2inICE -
Mr Brown/H2inICE
This adjuster is variable 15degrees.
Set the distributor at your lowest desired timing. Then get in the car and turn the knob up or down 15degrees. -
I agree to that, it's just that you dont get the right readings from the one you pointed at, just making shure you knew the ignition had to be retarded since you pinted out a advancing ignition controller
Btw for you guys runing EFI you can chose XFI F.A.S.T, they hawe realy good wire solutions for just about anny modern engine and you can adjust it easy with your laptop
Mr Brown / H2inICE -
Mr Brown / H2inICE
Not all those adjusters are as easy as u make it out to sound but ya its possible. -
If possible I plan on getting one of these devices when I get to the point of automobile engines. I wish they had an item that would do timing adjustment on small engines as I would like to get these working on hydrogen alone. I think this would be a great learning experience that would create more knowledge to tackle many of the problems associated with the use of hydrogen in larger engines. At any rate I am beginning small.
I think I would prefer many monitors while in the experimental stages while operating any type of timing control.
CarbedNotch,
Thanks for sharing about this. Great stuff!!
Here is a link to another site, where, someone is making a timing circuit, mechanically, to get rid of waste spark on small engines.
link
