GODS ULTIMATE POWER FOR HUMANITY THEORY
Started by unknown · · 21 posts
  1. outlawstc
    steve you can delete this thread it was full of to much theory not enough concrete
  2. Donaldwfc
    I don't know what you are talking about, maybe you are off your rocker, or maybe you are over my head. But I think you'll get some more concrete clues to what Stan was doing if you pick up a common physics university textbook.
    It's obvious that's what Stan did. The Water Fuel Cell is practically built from a combination of example problems in this textbook.
    attachment_3553 attachment_3555 attachment_3557 attachment_3559 attachment_3561 Photo 41.jpg Photo 40.jpg Photo 38.jpg Photo 32.jpg Photo 31.jpg
  3. Dankie
    Gentleman plz ....
    If you feel like boasting about your superior IQ or if you wanna fight  , just go to overunity.com and insult people , you can even curse at people's mothers and never get warned .
    Over here we are never confrontational , we are extremely lucky to have this very focused forum .
  4. outlawstc
    heres another gift from me of insight,
    look at this art work.. it represents earth.. look at the snow flakes around the outside.. you will notice they go from simplicty on the south side but then they get more complex as it reaches the north pole.. why? remember you got to learn to ask the right questions!!! its because the electron density grows as you head from south pole to north pole just like what stans chokes are doing!!! ok then notice that the equator is where scalar huricane form a hurricane is a action so its the earth doing work!! ..  i think that complexity of electrons build up reflect how we are on this planet as a society..   all the negative electron density builds in the north because earths more reflective on this side of the hemisphere?  so it attracts the electron density??? the south is all about simplicity compared to us.. they are not bombarded with dense electron count in capacitance volume sense.. it cause a 180 perspective of way in living.... the money spot in life for balance is by the equator..   vice versa means everything in nature has a 180 reflection..
    outlawstc
  5. Flaghole
    .....   all the negative electron density builds in the north because earths more reflective on this side of the hemisphere?  so it attracts the electron density??? the south is all about simplicity compared to us.. they are not bombarded with dense electron count in capacitance volume sense.. it cause a 180 perspective of way in living.... the money spot in life for balance is by the equator..   vice versa means everything in nature has a 180 reflection..
    outlawstc
    Interesting.  I've inspected numerous pressure vessels and tanks all over the US and Canada. Did you know that natural thinning of the shell in CFe tanks (i.e. A36 and 516-70 materials) is always greater at magnetic North? Especially when the solution in the tank is on the caustic side of pH. I always wondered what the phenomina for tanks looks like South of the equator. Wait a minute...
    What directions do hurricanes spin North or South of the equator?
    The mriaculous physics of God's creation has always intrigued me.
    Flag  8)
  6. electrojolt
    Humm, very interesting....
    how can we test all this theories??  Any Ideas?
  7. outlawstc
    why does the space shuttle have a black bottom and a white top?   because it faces its belly out toward space when in orbit.. it  has a attraction the the sun do to being black, while the white faces down to reflect and repel off earth.   how do the tiles stay cool and a insulating barrier from heat on re entry not totaly sure on that one.. they are some type of ceramic material? the shuttle flips to its belly on re entry so now tops facing the sun causing a repeling back toward earth with its opposing refelecting force and the black is facing the ozon so it is attracted to it
  8. Donaldwfc
    or because the windows are on the top and the astronauts want to look at earth, so they put the belly to space
    and the gravity pulls them down, and they need to be right-side up when they enter the earths atmosphere because the space shuttle is classified and built as a 'Glider' (google it) and it can't glide very well upside down while it's in the earths atmosphere.
    I think you are making this more complicated than it needs to be.
    K.I.S.S.
  9. outlawstc
    Amorphous silicon (a-Si) is the non-crystalline allotropic form of silicon. Silicon is a four-fold coordinated atom that is normally tetrahedrally bonded to four neighboring silicon atoms. In crystalline silicon this tetrahedral structure is continued over a large range, forming a well-ordered lattice (crystal). In amorphous silicon this long range order is not present and the atoms form a continuous random network. Not all the atoms within amorphous silicon are four-fold coordinated. Due to the disordered nature of the material some atoms have a dangling bond. These dangling bonds are defects in the continuous random network, which cause electrical behaviour. If desired, the material can be passivated by hydrogen, which bonds to the dangling bonds and can reduce the dangling bond density by several orders of magnitude. Hydrogenated amorphous silicon (a-Si:H) has a sufficiently low amount of defects to be used within devices. However, the hydrogen is unfortunately associated with light induced degradation of the material, termed the Staebler-Wronski Effect.
  10. outlawstc
    "Under the microscope, I found that snowflakes
         were miracles of beauty; and it seemed a
         shame that this beauty should not be seen and
         appreciated by others. Every crystal was a
         masterpiece of design and no one design was
         ever repeated., When a snowflake melted, that
         design was forever lost. Just that much beauty
         was gone, without leaving any record behind."
    Wilson "Snowflake" Bentley 1925
    http://www.cienciateca.com/stssnow.html
  11. outlawstc
    The piezoresistive effect describes the changing electrical resistance of a material due to applied mechanical stress. The piezoresistive effect differs from the piezoelectric effect. In contrast to the piezoelectric effect, the piezoresistive effect only causes a change in resistance; it does not produce an electric potential.
    Piezoresistive silicon devices
    The piezoresistive effect of semiconductors has been used for sensor devices employing all kinds of semiconductor materials such as germanium, polycrystalline silicon, amorphous silicon, and single crystal silicon. Since silicon is today the material of choice for integrated digital and analog circuits the use of piezoresistive silicon devices has been of great interest. It enables the easy integration of stress sensors with Bipolar and CMOS circuits.
    This has enabled a wide range of products using the piezoresisitve effect. Many commercial devices such as pressure sensors and acceleration sensors employ the piezoresistive effect in silicon. But due to its magnitude the piezoresistive effect in silicon has also attracted the attention of research and development for all other devices using single crystal silicon. Semiconductor Hall sensors, for example, were capable of achieving their current precision only after employing methods which eliminate signal contributions due the applied mechanical stress.
    [edit] Piezoresistors
    Piezoresistors are resistors made from a piezoresistive material and are usually used for measurement of mechanical stress. They are the simplest form of piezoresistive devices.
    [edit] Fabrication
    Piezoresistors can be fabricated using wide variety of piezoresistive materials. The simplest form of piezoresistive silicon sensors are diffused resistors. Piezoresistors consist of a simple two contact diffused n- or p-wells within a p- or n-substrate. As the typical square resistances of these devices are in the range of several hundred ohms, additional p+ or n+ plus diffusions are necessary to facilitate ohmic contacts to the device.
  12. Alan
    Haven't read much of your posts here lately, too much for me atm :P
    but you said matter and light are the same, and I came to a similar conclusion with some open questions:
    an electron
    is clearly a standing wave.
    Matter is a standing wave on the substance of space-time. Spacetime gets concentrated by C2 giving it the properties of matter, this costs and thus stores energy.
    What is gravity: imagine a rope with both ends tied to rubber bands, now swing
    the center of the rope until standing waves occur, the ends pull the rubber bands towards the inside.
    Standing waves of matter is pulling space-time's elastic properties inwards the same way, as a result a gravity (potential) occurs.
    Light is a traveling wave, this is the reason light flows over the space-time surface (with zero resistance, defined by the waves E and B and space-time's u and m) and matter doesn't.
    Light isn't a standing wave, thus no properties matter and zero mass is measured.
    Positrons are anti matter, meaning? negative mass makes no sense, it must have something to do with the properties of  its standing wave.
    Instead of pulling (contracting) space-time, it expands it?
    What keeps a standing wave in motion? Some interlocking mechanism or a constant flow of energy... self energy?
    Can its oscillating source interact with traveling waves (light), thus increasing the energy? Is this the way matter absorbs photons? No one knows what photons are, but everyone thinks he/she knows. They are a huge mystery.
    Are light and matter on opposite sides of the same coin, with the only difference the type of wave?
    Thus ends my brainfart.
  13. Steve
    I like your brainfart. Well written.
  14. outlawstc
    Haven't read much of your posts here lately, too much for me atm Tongue
    photons are the vice versa of electrons.. vice versa as we know are things like hot cold, wet dry, day and night.  so we can concled they are opposite states. ok the opposite state on the atomic level create vise versa effects to atomic charged particle positve and neg. making them have GRAVITY in opposite directions..
    the type of electric current we use in todays world(alternating current ) is what i call turbulent current when being used and we know of them as amps..  as you should know 125 volts AC has 1 hot leg 1 neutral, and a ground.. the neutral isnt hooked to their stator neutral of the generator at the power plant .. so there for it isnt a closed loop circuit what so ever.. they rely on pumping amps down a wire for a source of power down 1 hot leg, through the load, and then into earth ground.
    tubulent amps is where the heat comes from in conventional electric. see since they use 1 hot leg to send there power it is pushing electrons 2 times further then pullng back.. they travel 2 times further because neutral is like a dead short on the load side..  they use earths attraction to stabilization to help the load move down the line.. well every time you switch directions in 1 hot wire you are causing the copper atoms protons to flip flop back and forth, when they do that it causes heat by means of friction on a atomic level.  pole flopping of the protons of some sort..  proton matter is just like earth.. it is positve charged but has neutral effect as well.. notice how protons and neutrons cling  with attraction... well we humans are neutral charged and what do we cling to? earth!!!  so i would have to say the copper protons are pole oriented determined by the direction of orbiting electrons.
    resonance in stans set up is learning how to use electric in its tru calling.. a biderectional flow.. which would be putting a one direction flow for electrons.. your not pulling them back any more just push push push push.. and light is getting pushed pushed pushed in the other direction in same relative time although it may not be as much push as vacuum.. the rectifier is like a back flow preventor..  so once you figure out how to push one way with the alternator.. you know that the negative choke is becoming condensed with electrons while the positive choke is where the negative choke got its electrons from.. so it is short of electrons to be atomicaly neutral.. it has been put in a higher vacuum energy state.. which is positve.  the electrons being pulled out were traded for light.  so we know the positve goes into vacuum state and electrons are in a pressure state.. now you must understand balance of building states.. if you dont build them in a even in a  relative manner then you will created turbulent amps across the load which is the water.. waters viscosity has a harder time remaining pole oriented under unbalanced voltage fields..  the little amount of amps stan used was enough to keep them polarized while voltage performed work. im gonna draw up the difference in turbulent and non turbulent here soon.
  15. Dankie
    an electron
    Very nice brainfart .
    So how it is we do this now heh ?
  16. outlawstc
    for every action one trade take place, 0 and 1 polar matter displace. 0's the light and YOU ARE THE 1, what it amounts to is divinity..
    lol part of a song i wrote..
    in my mind for every action one trade takes place
    makes me think back to 2 pac days
    live by the gun die by the gun
    what he'd  say.
    the deal is we in the matrix and
    for every action one trade takes place.
    1 and 0  polar matter displaced
    0 is light and you are one and what it amounts to
    is divinity and in todays worlds filtered by luminosity
     they dont share the gift
    moneys the artificial  switch
    1913 freedom got ditched
    so take your turbulent disturbants
    go buy some detergent
    and make your own suds
    im ready to grab my guns
    play elmer fud  and go have some fun
    how deep does the wabbit hole go
    thats what im out to know.
    come out to playpesky wabbit
    visualizing a gun to his noes
    all i see is visual distortion
    my intuition says all seeing eye
    causeing govenment collusion
    hiding the fusion in lifes illusions
    as pastor troy say's
    look up in the sky nigga we rich..
    find your third eye and open it
    this is for the deaf dumb and blind
    please dont make me flip my mind
    from positive to negative
    we're all riders of the same storm
    which makes us dividend as well as innocent
  17. Alan
    Superstring theory I guess.
  18. Steve
    what he'd  say.
    Outlawstc: PLEASE USE DOTS IN YOUR TEXTS...........THANK YOU!!!!! You type such long lines....
    steve
  19. Dankie
    The aboe is called `Tower Speak```, it is much superior to normal talking
  20. Alan
    lol never heard of it, looks like its about putting trains of thought on paper.
  21. outlawstc
    steve
    lol my bad that just how you write lyrics... it helps keep you on rhythm.... each line is a flip kind like a cycle
