Electricity flow conserved for more use!
    12v lead acid battery is hard to deal with for exact readings of energy transfer, and release. The charged battery has quantity built up of pluses + and minuses - at each end, so as being unbalanced. The discharging of battery is seeking balance of charges. A large computer capacitor is readily available and responds to electronics math formulas. See 2 manuals from Eagle Research called Energy Conserver. A quality polypropylene capacitor is NOT an electrical load, only a temp storage means. Electricity passing over wire to resistive load such as lamp bulb releases light as work done. If opposite end is connected to capacitor, the in series current is absorbed into it, held, with quantity of electrons, not passing on to end connected battery terminal. If 2 caps are in parallel (with switches) and in series with other side of source power, the light stops at point, that volts match. The 2 caps are then put in series so as with higher volts. The power source is disconnected. The storage of same used current is rerouted back through bulb. The 2nd work done brightness can be measured as close same with lumens meter, and at approximately same time in seconds. Question- Does this bench test require power factor reading? This system could extend range of electric cars.
  2. sebosfato2
    You forget that the flow of electricity will consume power
    Is pretty much like pushing the breaks on a car
    Losses impede the flow and this consume the power
  3. russrHHO
    You have not yet done the bench test with 9v battery , jumper wires, bulb, watch hands in seconds, capacitor and test meters. Read the paragraph again. Do this without looking at the certificate mounted on the wall and the condescending PEERS looking over your shoulder. Amaze just yourself!
  4. sebosfato
    No problems… i just meant that sometimes we forget that when we do work by passing current it consume energy and some times is not so obvious… (i dont get a certificate haha most i learned was on doing the school just gave some very few tools to think too…
    when you charge one capacitor from another energy get destructed for example… but it wont show until you experiment with it and do the math…
    also coils can transfer energy and is hard to understand it until you try to get a high resonant Q factor on a tank circuit..
    When current flow we have the voltage drop that makes life hard because when it drops it cant get up again .. .
    as i tried to explain it works like a dragging force that goes against the movement
    I dont meant to disagree just wanted to add to the discussion..
    what you refered as increase in lumens is not impossible… if you for example are condensing the enegy in time the filament may go brighter and even break… or not last so long or perhaps the oposite. the fact is that you are probably manipulating the timing… did i understood it well?
  5. russrHHO
    Thee is no increase in lumens, only the bulb will light for the same 5 seconds at same amount of brightness , it did the first time with the same energy going into and coming out of the capacitor
    Test this on work shelf for yourself. Read the 2 manuals - 0nly if there is an extreme interest in alternate energy systems. .
