Basic components of the Geet reactor
Started by unknown · · 15 posts · last reply 5 August 2009
Here are the basic components of the Geet reactorgeet10a.jpg geet11a.jpg geet12a.jpg attachment_4589 attachment_4591 attachment_4593 attachment_4595 attachment_4597 attachment_4599 attachment_4601 attachment_4603 attachment_4605 attachment_4607 GEET Fuel Processor.doc attachment_4615 geet3a.jpg geet4a.jpg geet5a.jpg geet6a.jpg geet7a.jpg geet8a.jpg geet9a.jpg geet.jpg
finally something that will show real results that save $ .
everybody should make that their their car untill we have a real winner solution .
Paul Pantone is a great man . -
Looking good, Steve.
I read recently, that the device would work much better if it were NOT constructed in a horizontal plane. Have you read or heard anything like that ??
I could do some searching, if that would benefit anyone
What type fuel you using
Did it start on the Geet device, as well as run on it
The photo's are NOT from my engine, but from another Dutch person who already made a Geet.
His photo's and info are so very specific, that anybody can replicate this and can save fuel.
I am going to replicate his work soon.
The fuel used is water and used motor oil!!!!!!!!!!!!!!
Well, there is plenty of that, is it.....
Also used is saltwater with diesel.
Or diesel with petrol and water.
Most of the time, it is 80% water with 20% something else.
I seen somebody running this thing on COKE COLA and COFFEE
So, yes. Any help is usefull.
You are right and especially the vortices are supposed to move in the same direciton as the pistons.
Great job Steve!
Check out Leo Umila later, I believe that one is a good step after standard GEET.Looking good, Steve.
Good series, check all his videos on getting from 1.7 to 0.3 consumption! And still no dry steam used! -
Gauss that was a impressive video above.
Did he start that motor on just the cold geet. (how can it be?)
If so thats fantastic, I'm blown away at the simplicity.
Steve get building, I'm sure we all would love to see your results with Geet technology.
Not trying to be pushy or rude.
Just would be that much nicer the process is done and tested right here.
Best of luck and hope its as simple as it does appear. -
Harald,
Do you have more info on that vertical Geet thing?
I have been looking, Steve. Internet down here is slow and drops the connection, regularly. Monsoon type rains this time of year, and the phone lines, dial-up, leaves a LOT to be desired.
I DID find some, but, not the one I am looking for. -
Here is some of what I found.
I spent about 4 days with Paul Pantone several years ago. He told me that you can get electricity from the reactor rod. You need to insulated the exhaust pipe in the location where the reactor rod is spinning with peaces of tile and then coil a wire around the tile. When the motor is running and the rod is spinning the rotational magnetic field will energize the coil. So you could run the motor at idle and have as much electricity as you could ever use with NO back drag on the engine.
If you hold a compass close to the exhaust pipe when running there is a strong magnetic field. The longer the engine runs the stronger the magnetic field.
He also told me that he had a friend that did this. The results: the wire turned white hot and the multi-meter melted from the abundance of electricity. Is this true ? I have not tried it.
I was also told how to get a generator to run on only the fumes from a battery that the generator is charging. I was unable to get this to work. I could draw this up for you if you would like.
I was also told how to figure out what size rod needs to be in the reactor for each kind of fuel. Also running due North for 20 minutes or Vertical and not having to worry about the time limit. I have tried these two things and they work. Not sure if you know this?
I was also able to get a mower engine to run for 4 hours and was able to hold my hand on the end of the exhaust pipe without burning myself. This is just from fin tuning the length of the rod.
Another tid bit
I've seen that before and studied it a long time. I think the GEET
material is correct that the reactor can make such a strong
electrostatic field that it attracts electrical charges from a good
distance and when it works very well it is making a strong magnetic
field also.
It is also rumored to have 200% OU
Don't know about that one
Pantone has been released from the Sanitarium, and, is leaving the US, very soon, according to what I read. -
Thanks Harald!
Thats good info!
That would be great to try, is it. Create electricity! Looks like to me that the pieces are coming together....
Steve, you should try to run it with your WFC in the "fuel tank"(antifreeze bott) and just water. maybe even through on one of those Plasma Spark set ups. if its just 20% used oil, you might be able to get it on (water/HHO) only. worth a try. -
Well, It would be a pleasure to see the engine running with a Geet reactor and my wfc powering it. Then of course, the new made electricity from the geet reactor powering my wfc......
