Two Types Gravity Control Methods!
    Grebennikov Interference pattern generated to counteract gravity waves flowing upward in the ether, from ground. These were extremely tiny cavity resonators as from those bugs wings. His built unit to stand on, had the high voltage electrical field on metal screen from car coil, in same vicinity  as the 4 layers aided the process. The 4 gimbals would spread out the 4 layers , so as covering area of the lower board. Handle bar controls moved the cables for orientation. Mass above the board is weightless. Looks like the microscopic pores on a cd disc. The folded up unit would fit in very large microscope case, and had to be held vertical at all times , unless unit being used unfolded horizontal and stood upon. Russian government confiscated part of the unit. The lab is open to the public, but flying bug species is censored. The beetles did not fly in wet, humid weather. The wings vibrations generated high voltage electrostatics.John W. Keely from late 1800's also demonstrated gravity control with tuning fork array with ratio harmonic frequencies applied over thermopiles of silver, gold, and platinum wire transmitter, to heavy metal mass. Signed affidavits of visitors present during demonstrations were done.
    Nice topic.
    I have seen some articles about this bug wing high voltage finding. I am still wondering if it is true or fake...
    What are your thoughts?
    Cheers!
  3. sebosfato
    One very interesting one i saw used mercury as flow liquid and made it hit the ceiling of the (antigravity engine) in a manner that it gives momentum to the structure but is guided by electric and magnetic fields to circle and always keep hiting in one direction the point is having so much electricity to do that continuously
  4. russrHHO
    Unusual Gravity Control Experiments of The Past
    John Keely did science experiments in late 1800's and floated a few heavy weights as brass and steel. he used frequencies applied with ratios on wires we now call thermocouples and thermopiles. Wires as platinum, gold + silver , as due to resistance matching ratios. Heavy platform of 3 brass flywheels as sirens were also operated with air pressure to speed up to certain tones. Keely was musician and knew sounds. with tones change by ratio, along with mass chord, the whole unit would rise up and settle down with air withdrawn. A modern test of one thermocouple on digital weigh scales showed loss of weight, by itself. Documents available from Mr. Pond of S.V.P. I studied Keely for 8 1/2 years with about $500 in old papers.
    Controlled remote flying generator was done by Mr. Searl. It was a combination of rotating magnetic field and high volts electrical field same time. Silent, as no air at edge of hull rim was vacuum to pass no sound waves.
    Also Russian entomologist made floating contraption he stood on by high volts field over tiny cavity resonators on lower board. The tiny pores cause disruption of gravity waves emanating from ground. Anything above had no weight.
    French scientist had local newspaper article (translated from Babblefish) of floating open frame dirigible using sandwich plates of thermocouple at each end and excited by frequency generator signals. Device flown to next town and back.
    The late Mr. Baumgartner demonstrated a vortex swirl of air unit, low power, that that tapped into the ETHER field. Any weight , including him , and front end of city bus, on plywood form with small motor at high speed turning small turbine. The armature winding connections was changed from parallel to series to get a higher RPM. There are 3 types of spirals, - guess which one it was!
