Spherical Resonant Cavity Replication
Started by unknown · · 20 posts · last reply 3 March 2019
Interest in Stan's WFC seems to be at an all time low lately, but many of us have been and are still working in the shadows!
I post as HMS-776 but lost my email and couldn't reset the password here so I'm posting under my other username.
In Stan's early WFC work he made a Spherical Resonant Cavity to study the phenomenon he called 'Resonant Action'. Patents on the Spherical Resonant Cavity were filed as early as 1982.
About the Spherical Resonant Cavity, Stan stated:
"The motion of the gas atoms will pass out of the opening as though they are jet propelled."
"...the resonant cavity causes the water molecule to travel back and forth continuously and at a velocity that increases geometrically."
It's interesting to note that he stated the velocity increases geometrically... from this statement one can assume this system went into a runaway and the only way of slowing it down and controlling it was to "Gate" the circuit.
"This action continues indefinitely and will continue until the applied energy is terminated."
Reference
-WFC News Release #3
-Europe patent 0,103,656
Canadian patent 1,234,773
-WFC Dealership Sales Manual Chapter 5 'Mega Watt Gas Yield'
Looking at the dates of the Spherical Resonant Cavity as well as the picture in the WFC News Release # 3 showing his control circuitry we can see he used an autotransformer & his SCR pulsing circuits.
The spherical resonant cavity and its control circuit box is not anywhere in the estate photos?
Who knows where it ended up?attachment_15693 attachment_15695 attachment_15697 attachment_15699 attachment_15701 s1.jpg s2.jpg s3.jpg s4.jpg s5.png
Looks good your setup,
The question that rises is what
resonant action between which parts?
Thanks Steve,
IMO there are two resonances that occur within the overall system.
1. Resonance of the circuit
2. Resonance of the cavity
The problem as we all know is getting the first resonance to occur, without it we will not see resonance of the cavity...My question is, what has been holding us back all this time.....Drive circuitry? Choke values and/or balancing? VIC design? My opinion is that in lies with the VIC design, and that if we could get it working and understand how its designed we can solve a lot of other problems.
Time will tell... -
Here's a place which sells hollow ss spheres:
https://www.google.com/url?sa=t&source=web&rct=j&url=https://customironworks.com/balls-steelaluminumstainless-c-1/&ved=2ahUKEwjAh_u47MPgAhU3wMQHHSccDdQQFjAUegQIBxAB&usg=AOvVaw1Axhg-Q-a0UqVpcOMM3uwz
A 4" 304ss, with a 1/16" thick shell is $69. Anyone have other ideas? A sink drain plug has about the right shape for half of it - with holes - but I don't know if you can get ss. And don't use resteraunt cups, because they do corrode. -
I bought mine on ebay but you can get them online anywhere... just search 'Stainless bath bomb mold'.
I had to order several before I actually got a 304 SS one... it seems alot of people think aluminum is the same.
You can also get a one piece sphere in a variety of sizes if you search 'stainless garden ball'...
I used the two piece bath bomb since the flange made it easy to mount... also, the garden balls are really thin.
The center sphere is a 304 SS hardened bearing, 1/2" dia.... you have to heat it to red hot then cool it slowly by placing it in sand, after that file a flat on it before drilling.... or if you have a solid carbide bit you could drill it without heating it.attachment_15707 20190217_210724.jpg
This system is different from what Meyer usually worked with. The resonance diagram shows that the frequency increases with higher voltage. That means that, in this case, resonance refers to the pulses being timed to match the time of flight of the ions between the two electrodes. This is a classic example of a Farnsworth type system. So it's not powered by a VIC transformer. The positive potential has to alternate back and forth between the two electrodes. It needs to be fed with a tank circuit comprising a variable capacitor in parallel with a center tapped inductor. Examples of the wiring diagram can be found in Farnsworth's multipactor patents. -
The diagram shows voltage amplitude is "held constant"
This system doesn't require a step charging waveform. Once it's fine tuned to establish resonance, both the voltage and the pulse frequency are held constant after that. Increasing gas output is automatic, without increased potential. But geometric output does require additional current, so Amp restriction isn't used. -
I've been snowed under here lately; this time of year, fire wood labor requires way too much of my time. But I finally took some time to read the Canadian patent, and this isn't what I thought it was. It CAN be used as a Farnsworth system with a vertical seam and insulating gasket between the two hemispheres, and a loose mesh for the central electrode. But the patent states that the electrodes maintain the same respective polarities. So it's a normal Meyer type system.
There is some uncertainty with his usage of the term resonance. He says the particle velocity increases indefinitely, without periodic gating. So the resonance frequency must be related to the gating period. This is shown in the chart as a relative proportion to the voltage. (Which he said somewhere needs to be at least a kV). The pulse frequency itself is shown relative to the gating interval.
One issue I have with the patent is the suggestion that the cavity be sized according to a pre-selected resonance value. I think it would be better to do what Adrian did and build it with available components, then determine the resonance of what we have. -
The Canadian patent includes the word longitudinal, so Stan appears to have believed these waves were present in his spherical cavity, whether he understood that mechanism or not. In this day and age, the biggest impediment to understanding these waves is the rubber band analogy in which it is stretched, then relaxed, producing an expansion followed by a compression of the rubber along its length. What actually happens, according to the old school teachings, is that the rubber band is stretched a certain distance in a specific amount of time, held constant for an equal amount of time, then stretched some more. There is no relaxing, or recompression in the opposite direction.
From the perspective of the ether, the longitudinal wave has two parts, North Pole and South Pole. The first half of the wavelength is like a narrow band of ether curling around a line pointing in the direction of travel, while not overlapping on itself, but expanding a little as it travels. (Like a strip wrapped around a long narrow funnel, getting a little wider along its length). This is equivalent to a North Pole line of magnetic flux. At the half wavelength distance the magnetic polarity flips to South Pole polarity. But this doesn't mean the flux line reverses 180 degrees. Instead, the South Pole flux tips to the side, 90 degrees to the direction of travel. This causes the ether to rotate in place, with no travel. It's like a clock spring, turning in one direction and compressing as it absorbs the ether's North Pole momentum, then expanding as it rotates back in the other direction. This reaction counter rotation reconstructs a North Pole flux line, extending the longitudinal wave's travel.
An interesting thing about the North Pole curl is that it will accelerate charged particles which are within it. (This is what cause the extreme, short distance acceleration responsible for producing the solar wind). Stan presents his device as being capable of Mega Watt gas output, while the patent states that a very small amount of amps are required. To do that, the device would have to use Longitudinal Waves. -
Tesla believed that longitudinal magnetic waves can't exist outside of a vacuum. In a physical medium, magnetic forces will interact with matter, producing electric fields which convert the waves to electromagnetic energy. However, he did bounce some kind of longitudinal waves off the moon. These waves may have been electrostatic or diamagnetic. Both of these effects require two signals, just as do Tesla's Stationary Waves. Standing Waves, on the other hand, are composed of a single wave and its reflection. All of these waves can impart longitudinal movement to a charged particle. But it's interesting to note that Meyer used TWO epgs to power his dune buggy. With this apparatus, it's easier to adjust the wavelength to match the distance from the end of the injector to the top of the piston. (Or the other side of the cylinder).
If a VIC is used with a spherical cavity, determine the wavelength of the VIC's output, then size the cavity to resonate with the available signal. Or else use some other way to produce the biphasic energy which allows the output to be adjusted to match an existing cavity. -
Farnsworth's diagram shows that the magnetic field tips 90 degrees when the electric field reverses at 180. My biphasic longitudinal spark illustrates this effect. (The positive force in this example doesn't regenerate, with further extension, because the negative spikes separate in different directions, lacking overall rotation.) At 7.5 kV, I'm getting just over one half inch per kiloVolt, although this factor is likely to be different when dealing with water. For resonance, the length of the positive part of the spark needs to match the distance between the electrode surfaces. With very little current, a number of pulses would have to be applied to drive the spark's full extension. (I did see someone else's rapidly rotating negative spark one time, shooting for more than two feet, continuously.) I was lucky to get the picture I got, with a single pulse from a large capacitor which was barely big enough.
The patent mentions the electrical polarization process, but this particular system would need reverse bias. The charged particles are repelled from the positively charged central electrode, rather than elongated in place, so the positive side of the molecules would need to face inwards.attachment_15709 attachment_15711 F517.gif shootingspark.jpg
Ive allways wanted to know if the impedance card Stans brother shows in his patent was also included but hidden in Stans circuitry? -
I'm building a pulse unit which combines the ripple voltage from two capacitors, each with its own diode T-tap circuit. One cap has an inductive bend, which provides a phase shift. I got the motor/generator system off of YouTube. I pulled the gears out of the MW oven turntable motors, then coupled the DC motors directly to the spinning magnets. With 12VDC to the top motors, the bottom motors put out mains voltage AC. One DC motor is a little smaller, so its cap's frequency will be slightly lower. This will produce a beat frequency in the output, something which can accelerate charged particles in a plasma. The ripple voltage outputs from the caps are combined through a resistor. With rf, this would need to be a pad. The output from the resistor will have to be at least a #10 AWG, to avoid adding additional impedance. And there are, of course, other ways of generating the ripple voltage. Stan's brother supposedly knew everything he was doing, so there's a good chance Stan was using what Steven shows.attachment_15713 Pulser.jpg
Thats nice....are you familiar with envelope detector curcuits and why they are used?
With this spherical cell...the patent plainly says water but doesn't a gas seem more logical ?
I was pretty sure Samuel Leach had a patent for a similar configuration aided with a laser but I cant find it to post for reference.
Im replying to just be a part of the conversation,I havent built this type cell yet....it looks interesting!
I dont know the significance of the different degrees of pulses in fig 2 of the Canadian patent ....can someone explain that?attachment_15715 Screenshot_20190302-025803_Adobe Fill & Sign.jpg
I haven't heard of the envelope detector circuits, and don't know if I would have the skill to build one. But they sound interesting, so I'll check into it. Thanks for the tip.
I think the sprerical cell can be used for either gas or water, but they would have different size resonances due to the differing break down voltages.
The diagram with the increasing pulse intervals represents a type of resonance in which pulses are applied at the begining of each vibration, when the vibrations have increasing amplitude, with longer and longer periods, as opposed to applying a number of pulses, each of which directly increases the magnitude of a single ongoing elongation of the molecules.
And I think eveyone here appriciates your input; you don't have to build something to discuss how it might work.
watch this...
That's a better video than the other one I saw. The key point is the wavelength in water is about one tenth of what it is in air.
But they still don't understand what's going on. The effect isn't based on heat - it's caused by standing waves pumping electrons. The effect doesn't happen unless you do it in a hot spot, where MW's overlap with reflected MW's. You can get the same sparking with a sharp metal object. It's the sparking which ignites the grape or toothpick.
Now that we have a relative idea of the resonance in water, how do we define the frequency of varying delay pulses? Is it still pulses per second? -
I just checked and the speed of light is about 3/4 of what it is in a vacuum. (2.25E8). So that's the fraction we need to base our resonance comparison on. And this also refutes the video's explanation of a sparking grape.
I've done a lot of work with this MW oven sparking effect, and I can get a much bigger plasma ball under a Pyrex cup. And I do have a 'secret project' which is like an Ace up my sleeve. -
Standing Waves can also pump positive particles, using the point of a safety pin as the central electrode. The direction of this movement is perpendicular to the sparking. Twist the pointed end of the pin out at a 90 degree angle, then put a bend in the other end, to form a triangular base which holds the pointed end straight upwards. Put it in the MW and the point will turn white from the electron emission produced by the standing waves. Then the point will start to boil off, with metal particles flying straight outwards. The sputtering effect is caused by negative ions in the air impacting against the point, which is positive due to loosing the electrons. Impacts cause the boiling, but not the outwards acceleration.
So I'm wondering how thin a layer of water would have to be to not block this effect? If the water sputtering does happen, there's a good chance of dissociation upon impact with the ball electrode which forms on the top end of the pin.
