mystifying
Started by unknown · · 12 posts · last reply 16 March 2017
  1. Hydrocars
     ::) Still Today nobody has found the answer, Im still here, watching, listening, smiling.. Once I gain, briefly i'll repeat myself, Go disable your pop off valves and shoot from a distance. And, use caution when removing a ratiotor cap.  ???
     ;) nice one
    He is still alive  :)
  4. Hydrocars
    hello old friend.. im 14 court cases in.. Its been a long going process, and very disturbing doing the custody battle. After 18 years with her and having 3 children, 2 living, they ruled we was not married after plenty $$$.
    I cant seem to understand why the people here in the research group hasn't discovered the true answer to water for fuel. If a water heater flys upward, is it not a rocket and was it not fuel that thrusted it? Why, why, why is it so hard to understand that if you raise the pressure you raise its boiling point, and if the water is above its ambient boiling point then, is it not common sense that releasing water at this pressure (125) and temperature (superheated) will thrust the piston downward when injected 5 degrees or even retarded, as it hits the aluminium cooler called an engine.
    I am sorry to hear about all those divorce crap.
    Hope you still see yr kids.
    About that pressure idea for water, did you had any change to test something on that?
    cheers!
    Some data on water under pressure.
    Data are based on the equation of state recommended by the International Association for the Properties of Steam in 1984, as presented in Haar,
    Gallagher, and Kell, NBS-NRC Steam Tables (Hemisphere Publishing Corp., New York, 1984). The temperature scale is IPTS-68.
    Note that: 1 mbar = 100 Pa = 0.000986923 atmos = 0.750062 mmHg.
    P/mbar T/°C P/mbar T/°C P/mbar T/°C P/mbar T/°C
    50 32.88 915 97.17 1013.25 100.00 1200 104.81
    100 45.82 920 97.32 1015 100.05 1250 105.99
    150 53.98 925 97.47 1020 100.19 1300 107.14
    200 60.07 930 97.62 1025 100.32 1350 108.25
    250 64.98 935 97.76 1030 100.46 1400 109.32
    300 69.11 940 97.91 1035 100.60 1450 110.36
    350 72.70 945 98.06 1040 100.73 1500 111.38
    400 75.88 950 98.21 1045 100.87 1550 112.37
    450 78.74 955 98.35 1050 101.00 1600 113.33
    500 81.34 960 98.50 1055 101.14 1650 114.26
    550 83.73 965 98.64 1060 101.27 1700 115.18
    600 85.95 970 98.78 1065 101.40 1750 116.07
    650 88.02 975 98.93 1070 101.54 1800 116.94
    700 89.96 980 99.07 1075 101.67 1850 117.79
    750 91.78 985 99.21 1080 101.80 1900 118.63
    800 93.51 990 99.35 1085 101.93 1950 119.44
    850 95.15 995 99.49 1090 102.06 2000 120.24
    900 96.71 1000 99.63 1095 102.19 2050 121.02
    905 96.87 1005 99.77 1100 102.32 2100 121.79
    910 97.02 1010 99.91 1150 103.59 2150 122.54
  7. tektrical
    Well, there's something I hadn't thought of: I can pull super heated water from the RADIATOR. And I can take the back two cylinders on my straight six and use them to pump up enough air pressure to run the other four cylinders. The question is, where does the heat come from to boil the radiator? AND, what do I do with all those pulses from the motor driven alternator?
  8. tektrical
    I'm the last person who's going to dispute that Free Energy is available from water. I've read reports that a water arc explosion produces 200 times the energy needed for detonation. The primary issues I see is that most of the output energy appears in the form of light and sound, with heat and pressure being less significant. The other thing is that any pressure produced is immediately followed by a collapse in the form of suction. So there's no net pressure blast. However, if a nano fog could result from spraying hot water under pressure, THAT could be ignited by a Ball Lightning type discharge. Especially if hho is added to the mix. So my assessment is that we still need the VIC.
  9. tektrical
    Something else I'm thinking about is  the GEET would run off of Mountain Dew, which is carbonated sugar water. This was without compressed air. Perhaps the 125 PSI, from the atmosphere, would ensure an adequate amount of CO2? I've seen more than one demonstrated electrical effect involving combustion produced CO2. Without hydrocarbon combustion, the needed gas could come from compressed air.
  10. tektrical
    I just picked up a nice four cylinder 33 cubic inch military spec boat motor at a yard sale. So I'm going back to working on my Injector project. I'll use the back two cylinders for the compressor, then put pressure and hot water through the plugs , into the front two cylinders. Then hit it with my electrostatic fire ball spark. Just to see what happens. And thanks to Hydrocars for bringing me back on track.
  11. Steve
    good luck!
    And we all are of course serious curious on yr progress.
    Keep on posting  :)
  12. tektrical
    Thanks Steve.
    But posting is getting harder all the time because of the hackers. It's starting to get real stressful, just staying online.
