It Runs on Pure water! no Gas!
Started by unknown · date unknown · 15 posts
here you go, view these videos while you can, if you have a way to save them to your computer and post them here please do so..
also, you had better watch these before they get gone! the man claims pure water here in my area, i tried to call him but no answer.
http://www.whnt.com/global/story.asp?s=8311741 check the boxes and click view videos. -
I foresee a black escalade visiting him in the near future... $5500 talk about rape and pillaging someone.
-raptor -
i like your way of thinking! -
Aloha,
The car on YouTube has a very similar function to the design
we have been discussing on oupower.com under the heading
re-enginner an ICE to run on hydrogen.
This is a project that I am currently working on using a 3.5 hp briggs.
Bill -
I could sell the items but I really want to see the oil and power genaration companies take a noise dive in proffets for all the harm they have done to humanity. That is my reason for giving the technology away, for they are starving people to death on purpose. They are killing people in Iraq right now, and have already started killing people in Iran, just to take control of thier oil, and put the hurt on the world as a whole.
Now where I do intend to make my money on this is in maintance, and instalations, just like the Automotive companies do. But I will not charge for the technology that will be free. Think of it this way guys, if you are a TV repairman and no one has a TV you are going to starve right? But if everyone has a TV you can earn a living, so give the technology away and WE will be the TV repairmen.
I agree 100% with you -
The second video (I believe in Japan) explains that water vapor is injected into the cylinder just before the hydrogen is detonated by the spark plug. Upon detonation, the water is turned into steam which expands at a tremendous rate thus increasing the power stroke of the engine. If my thinking is correct, then this would decrease the amount of hydrogen required to make the engine run. Basically it would become a type of steam engine.
On that note, couldn't the fuel injectors be used to inject the water mist into the cylinder, and the amount of water injected be controlled by an EFEI module? I am curious to know if anyone has tried this and if not is anyone at the point in their project that they could test this.
I have just only received my tubes yesterday and am still looking for a electric motor to drive my alternator. So I am no where near ready to test this out. But unless I hear otherwise, I will implement this theory on my test vehicle once I am at that stage.
LapperL -
Aloha,
Lapperl- If you are thinking of doing this on a vehicle you must also;
1. Change the timing in a major way, about 90-120 degrees after TDC.
2. Change the cam gear to run 1-1 instead of 2-1.
3. If the ignition is not run off the cam, you must make the ignition fire twice it's current number of times.
4. Remove about half the trailing edge of the intake cam lob.
As you will be converting from a 4 stroke to 2 stroke.
h2opower- It is my understanding that Stan ran the exhaust back into the intake to slow burning, as a result of the exhaust contained no flammable gases.
The piston is also pushed by adding fresh, cool nitrogen from the atmosphere, as the nitrogen (85% in air) expanded greatly in the combustion process.
As your engine will be breathing much less air, and hydrogen as the fuel, you will need much less intake of fresh air, yes, this will use and run on much less hydrogen than a conventional gas engine.
Bill -
Mrgalleria,
I,m not quite sure why you think you would have to convert the engine to run as a two stroke rather than a four stroke. I do understand the need to manipulate the vehicle timing and fuel injector timing.
In theory:
1. The engine takes in HHO gas which we supply to the intake manifold and drawn into the cylinder via vacuum from the intake stroke.
2. The engine compresses the gases and the injector adds the water mist.
3. The spark plug fires and we achieve the power stroke.
4. The exhaust stoke and we start all over again.
Injector timing can be altered via the cam sensor and volume of water can be controlled by an EFIE module.
Thats my theory, to maintain the four stoke process.
Any input on this theory is greatly appreciated
Lapperl
If I'm understanding it correctly, By converting it to a two stroke.
-Your intake valve would close at about 25 to 30% of the stroke.
-At 60% of the stroke, the cylinder is fired. While under an increased vacuum, lowering the combustion temp needed and turning the h2o mist into a combustible state.
-At full stroke the exhaust valve would open until it reached TDC, Where the process starts over.
This is why when we were kids, The 2 stroke dirt bikes kicked butt, And the 4 strokes sucked. They could get more power out of a smaller engine.
Spike -
go back and watch the added video, they guy was wrote off as a scam.
Hydro
I can't seem to pull up the videos, that you posted about
Spike -
Aloha,
Spike gets it.
With gas, you waste probably 30% of your power pushing a compression stroke to get the gas to explode (plus create excess lateral stresses on the piston, with excess friction and heat). Hydrogen is ready to go without compression (which may even degrade the hydrogen). With gas you need to mix in a lot of nitrogen bearing air.
You get oxygen with your hydrogen, and a small combustion area means you only need a small quantity of nitrogen for effecient power. Adding water mist to the small quantity of incoming air will accentuate the power, as we know. It's a win-win. Now we just have to put it in operation.
Bill -
h20power your entering the automotive x challenge also what are your highest efficiany and out put to date -
KEWL!! I've been wanting to see you guys enter that compatition, thats why I posted the Automotive x prize thing. Maybe once this thing is working properly, you can all get together and enter. I'm just sorry I currently am not able to help you guys with these projects, but I still want to contribute.... If you ever need any 3d work done to show off something let me know.... thats my field of expertise. Plus like I said once I'm caught up on some bills I'm ganna donate to this cause. The Future is here and I want to be there to tell the oil producing countries to go shuv it! We can also tell nuclear junkies to go shuv it too. Well thats my 2 cents for now.
FPhreek3 -
what a greedy bastard $5500 dollars for his gen.......i have a feeling he will get his rightful compensation......gosh greedy bastard, it really eats me up, hes toatally missing the point
