is it this simpel?
Started by unknown · · 12 posts · last reply 21 March 2024
How about just applying 300v to the LC and then get like 600V?
Or apply 600v and get 1200v?
Is that the secret?
https://www.falstad.com/circuit/
5v in and then 12v on the lc?
$ 1 0.000005 0.14549914146182014 60 5 50 5e-11
R 224 208 160 208 0 2 4000 5 0 0 0.5
d 224 208 304 208 2 default
c 384 208 384 272 0 1e-8 12.94743904804715 0.001
l 336 208 336 272 0 0.1 0.004471363575513091 0
w 304 208 336 208 0
w 336 208 384 208 0
w 384 272 336 272 0
g 336 272 336 320 0 0
o 2 1 0 4098 20 0.1 0 2 2 3
o 3 1 0 4098 20 0.1 1 2 3 3
How about this one? Added a resistor for preventing the leaky cell to leak to ground.
Input is 24v and LC is doing almost 30V...
R 224 208 160 208 0 2 4000 24 0 0 0.5
c 384 208 384 272 0 1e-9 -5.3304916036722716e-11 0.001
l 336 208 336 272 0 0.01 0.015731775123604987 0
w 304 208 336 208 0
w 336 208 384 208 0
w 384 272 336 272 0
r 336 272 336 320 0 1488
g 336 320 336 352 0 0
o 2 1 0 12290 29.851620783001223 0.0001 0 2 2 3
o 3 4 0 12290 29.879374367328996 0.0001 1 2 3 3
or at 50khz
$ 1 6.25e-7 0.14549914146182014 60 5 50 5e-11
R 224 208 160 208 0 2 50000 600 0 0 0.5
c 384 208 384 272 0 1e-9 586.9033082256366 0.001
l 336 208 336 272 0 0.01 -0.14125218975098347 0
w 304 208 336 208 0
w 336 208 384 208 0
w 384 272 336 272 0
r 336 272 336 320 0 1800
o 2 1 0 12290 766.5923081657502 0.0001 0 2 2 3
o 3 4 0 12290 770.6036791260528 0.0001 1 2 3 3
Is that the secret?
See Stanleys text in the attachment...
In this words I guess he is saying that at resonance the current on the components will cause the voltage to be greater than applied voltage... the voltage will depend on q factor...
He seem to say with that the resonance will allow a higher or different electric field 🤔 -
Is that the secret?
a different? What does that mean? -
When I did some tests feeding the cell with dc current thru a coil i was expecting that when I applied ac on the cell thru a capacitor would have mixed the electric fields in the cell however kind of it just worked in parallel being the cell connection just the point where the two circuits meet.
I was expecting that when I modulated the cell positive the choke would reinforce it and if negative the choke would absorb it.. it did it but not as much as I wanted.
When a coil find a higher resistance it need to develop a higher voltage to keep its current flowing so my idea was perhaps that maybe one coil modulating each other could give rise to a high voltage or field when they interfere with each other -
Please run this simulation:
$ 1 1.0416666666666667e-7 0.8031194996067259 34 5 50 5e-11
T 64 176 128 208 0 0.02 1 2.220446049250313e-16 -0.008815245999079346 0.999
c 352 128 352 224 0 3e-11 517.2170237049435 0.001
w 304 128 352 128 0
w 128 176 192 176 0
w 192 176 192 128 0
w 224 128 304 128 0
w 304 128 304 176 0
w 128 208 192 208 0
w 32 208 64 208 0
w 352 224 224 208 0
v -80 208 -80 176 4 5 50 12 0 0 0.159154943092
s -80 176 32 176 0 1 false
T 192 208 224 176 8 0.02 1 -0.00881524599907968 0.008809936181268463 0.999
d 192 128 224 128 2 default
g 352 224 352 256 0 0
w 32 176 64 176 0
w -80 208 32 208 0
181 224 176 304 176 0 300.03343262931946 100 120 0.4 0.4
o 1 64 0 12291 5559.406192123504 2.10693571926386 0 2 1 3
o 10 64 0 4097 0.0000762939453125 0.8 1 1
o 13 64 0 4099 640 0.00625 2 2 13 3
https://falstad.com/circuit/circuitjs.html?ctz=CQAgjOB0AMAsYDYnJUg7AUwLRpAZkgFYBOYvPMADkr0IQCYbiERDpXX3DswwAoACogEscGhZhGIetEoh20GPXAgshSHnrFoaaISoyd+noVUFi4hBfqwbsyWFyLSxPgGN8hZZLm1l9G3l8HghmBGhFMFs8anpCWnkYaH4Ad3w4cCk-TLloPjSfMQlib3F5fPASosrvKTy0gNFCvAzC+vSmrNay9sKZOTAq-vK0zWlZYVFh9uzG6UDpvgA3VUp2Yaw16tFTNkyghUgwEmPYYlgWkr4AZ1X2RxYxh6CIADMAQwAba4xBGvG5HNnrklCosOZLNZbLBZDILvhIMwSNAAjZUXFKKJnKQ+AATf59QJ9EC4jAfACunwALnwAOaefyBWZ0A4VJ5lETVdqbdYTMaLKgQIFlFpNHrpMCQNAUPAIRCYmRSMARTKHLGQWB8AD2Kk59wCxAgUTQAUUCHihDo50cu0gVgQaENsEIazQlHNEHWKjw2vA7D1IBhFkSEQi4i0eHO8UkpgQGpU3nYPqAA -
Sorry for the delayed reply
I took a look on the simulation, seems like the electron extraction circuit
Having such a small capacitance anything we put in become high voltage..
This month I have got some business to finish and than I will be able to start some testing next week
I will be focusing on getting the water to generate electricity and gas at same time but I will be following those two or 3 major lines I talked about last year
One using the electromagnetic fields to shake water and or induction to make the process and secondly using ultrasound as direct power input seem to me the later is the easiest path to go and also this days the most expensive
The idea is to get a resonant structure that allow the water velocity to be at max where the electrode sit
Interaction of the electromagnetic and the velocity will converge in the electron extraction ckt in my opinion
I just consider it as a full feedback
This year everything will change!
After some thinking about Stanley’s work
I hardly believe it was relying only on stainless steel
He certainly used a dielectric to be able to get the fields required to liberate the electrons
Charging it positively will get the electrons on the dielectrics and violently reverting it with a very strong negative pulse would make this electrons have energy to go out of the system and burned out in a emission filament -
Eccles use two capacitances.. Stan may have used a couple of cells
When we charge the cell we are adsorpting ions without effectively breaking perhaps the very negative spike force the ions to dissolve back but losing the electrons leaving the negative charge behind
That’s my two cents on it -
A long long long time ago, somebody told me that he used 2 glas plates, water in between, and alufoil on the outside, not in contact with water.
He had seen some interesting things.........
