I Cracked it!!!!
Started by unknown · · 78 posts · last reply 6 December 2022
  1. Hydrocars
    I'm Proud to say I cracked it all! No, I dont give one damn shit about any credit, Im just glad this shit is finally over with!!! I've been researching this technology between tesla and stan for 25 years or more.
    I was going to make a youtube video because I did want the views, not sure how that pay tube junk works and Im limited on time being I can only test on the weekends.
    I will leave you with this grain of salt, for one, Because what I'm about to leave you with is all you need to know. So here be the small sentances.
    I used a Step up coil from a Central Heating and air unit, (The Gas Furnace Igniter) All furnaces doesn't have them. The secondary measured around 1k ohms. I used the Telsa Mini Circuit on the net that containes just 1 resistor, 22k, I used a 2A224J Capacitor between the Source and Drain of the IRF740, Any N channel mosfet should do.
    Heres where it gets tricky, You use 2 diodes and connect them to the output of the transformer, (Led Light emitting Diodes work best) Connect one opposite than the other. Now you should have 2 unconnected Ends. (That goes to your fuel Cell). HOWEVER, the (Contactor switch) from a Heating and Air Unit, (COIL ONLY NO METAL CORE) shall be placed between a Single round Tube Cell about 2 inches tall or so and one of the Diodes. I did this on the Negative side. This Circuit is Dangerous!
    Thats all, you can produce hydrogen with only 1 wire folks, Thats right (A OPEN CIRCUIT) Produces hydrogen.
    Unfortanately, Mosfets cant handle whats needed to be done here, Tubes will have to be used later, Thats another day for me. Everytime I start getting good production The fet Blows due to the back emf getting to high. Also, you will not be able to touch the leades of the fuel cell, I had a arc go threw my finger and it burnt a hole in the end of my finger. These are Radio Frequencys so you dont get shocked anymore, you get FRIED!! You will smell your skin smoking and the room will be filled with Smoke from your finger, this damage only takes a Nano second so you cant avoid it, this circit is nothing to play with.
    Also, I will leave you with this un needed information. Telsa make Electric moters, they was 1 2 3 and so HORSEPOWER. I will say this another way because my time is limited here, 1 Horse can Pull 8k Pounds, so this means 2 horses can Pull, yup, you guessed it, 40 Thousand Pounds or close to it! So yes, Tesla's HP Moters, I mean, Energy Converters are like that!
    Tesla Used 2 coils to power his Ac Generators not 1, Tesla Knew about horses, he used a Symbolic 2 Horse Coil ( 3 to 4 times its Load) to puse it into a Ring of (Sets of coils) ontop of Sets of More Coils) to step Electricity around in ways that is not seen to man on this earth as this information is public but not understood. Anways, thats not really important, What is Important is you understand and learn how to connect an ac Output wires To itself and make it run on 1 wire!
    I will say this one last time before I go, that water Fuel cell is a (OPEN CIRCUIT) , Thats how it runs, I Gaurantee you this is a fact, I Put it on my life!! I say this because I know for a fact because I have been producting hydrogen this way for sometime now. Do Expect me to come back and reply to this forum or dont expect me to answer any question at all, because it may be weeks or moths before I log back in to this site.
    Just so you understand, 1 wire goes to 2 connecting diodes, the unconnected ends of the diodes go to a fuel cell with a coil their between with an (AIR CORE) and Leds are used for the Diodes, I tested this setup with stanleys diode and it would not work. and again, this Circuit is dangerouse!
    I used a Vacriac as the power source, and I Rectified that, and used 2 big capacitors to smooth everthing out. Build the circuit, raise the voltage! And get ready to blow some fets! I've blown a ton on this, and if you think the fet is blown, dont be so fast about replacting it, Turn up the voltage High, High enough to make the fet revive itself. You will eventually learn the circuit works and that Fets are no good, then you will get excited about what your doing and start looking for new ways other than fets.
    Your cell phones will not work with this circuit running, your laptop will malfunction. Funny things around the house will start to happen. This is No Joke. Good day!
  2. tektrical
    This all sounds pretty good, but I don't understand the "single wire" part of it.  Two diodes connected to the cell, one with a series inductor?  Where's the open circuit?  Are BOTH diodes hooked to the same transformer wire?  If so, how is that the negative side?  Is there a rectifier?
  3. Hydrocars
    I will make a second post. With a video, then I ask you to share with as many people possible.
  4. tektrical
    I'm starting to get a handle on this.  Both diodes are connected to the same transformer wire, with the diodes in reverse polarity and the other transformer wire left open.  The inductor is connected to the diode with negative polarity and the inductor's output is connected to the water cell, along with the other diode.  The transformer isn't rectified, or fully loaded.
    This is an innovative approach to the single wire circuit.  Normally, both transformer wires are connected to a spark gap with an adjacent single wire electrode's circuit terminating on a polar mass.  (Which in this case would be the water cell).  With both approaches, the current flows up one side of the wire and back down the other side of the same wire.  At high frequency, these bidirectional currents are simultaneous.  Using the two diodes allows it to work with just one side of the supply, which is otherwise unloaded.
    In my opinion this is a significant discovery.
    Quote from: Hydrocars
    link=topic=4126.msg34007#msg34007 date=1587542733
    Thst sounds promising, Brian.
    I cannot wait to see yr video on this.
    Well done!
  8. X-Blade
    It looks to me as another fantasy...
    "Extraordinary claims require extraordinary evidence"
    I think it's time to show it working the way you said it does, without "free energy tricks".
  9. Hydrocars
    Stevie, that might work, test it and let me know, X-Blade, I'm very sorry as my time is very limited as stevie can explain, as his is to. I mean no offense when I say I have a life. Patience! You will have your video proof in about 45 minutes... guys, please understand the future is in your hands not mine, I can't test this technology the way some of you younger guys can, hey, I'm counting on allot of you guys here to finish this!
  10. Hydrocars
  11. Steve
    Thank you for the video!
    My first impression is that it looks very similar to the Stiffler circuit with these two diodes.
    Stiffler also worked on the one wire power transfer.
    Great stuff
  12. Hydrocars
    I suggest paying stiffer more attention! I'll look him up. Invite him here.
  13. tektrical
    I don't see any relationship between this and Dr. Stiffer's free energy claims.  This is something new.  It's not even related to the Avramenko diode plug.  Attention should be given where it's due.  Otherwise, what's the incentive for posting at this site?
    And hasn't Stiffer already snubbed an invitation to come here?
  14. Steve
    i just send him a comment on his youtube channel...
    Maybe he comes...
  15. Hydrocars
    I'm planning on making a bigger version of this, in my video I didn't have it turned fully up because I didn't want to blow the mosfet. The rf burned is the most brutal burn I've ever felt, it leaves a black hole in your finger and theirs no avoiding it if you touch it. The leads of the fuel cell has kilo volts on either tube. It's not operating from a low voltage. My next step is to use tube now a few, and I want to try a transistor. I have no clue how to connect these tubes or even how they work. And thanks Tectrical!
  16. tektrical
    I'm wondering:  if touching either Cell electrode results in an rf spark, what will happen if an additional polar mass is connected to one of the electrodes?  This would be a single wire leading from the cell side of one of the diodes to something like a MOT core.  Or perhaps to a single electrode in a second Cell.  Remember that a human body is essentially a polar mass itself.
  17. Hydrocars
    and yes, it does!
  18. Hydrocars
  19. Steve
    Brian, those are very very cool test,s you did.
    I am proud on you. Never give up, i would say.
    You are the first showing high voltage on the electrodes of a Meyer test setup.
    I never seen anything like this before.
    My comments : i think that your coil between the cell and diode, is picking up power from the secondairy.
    That closes that part of the circuit.
    Question: can you try separating the cell with diodes and coil , from the high voltage transformer?
    Just use a long wire between them.
    At least 2 meters would be good.
    I wanna know if you see bubbles with that distance..
    Man....!!!! Wow!!! Those sparks show a voltage of at least 10kilovolts....
  20. Hydrocars
    I finally fried that mosfet last night the one in the video I believe it's a 13 45 or something another of that nature anyways I compared it to another one by installing another smaller mosfet like seen in the original videos let me tell you what those small mouth puts blow almost every time the resistor and one of the original videos was in the wrong place I was only following the meaning Tesla circuit eventually figured it out and moved it over from the gate to the source it's a 1 million Ohm resistor and that is where it belongs however sometimes I have to put my finger on the resistor to get the circuit 2 resonate. Also I was able to light a 12 volt light I'm the secondary call by connecting a lot between. Cole and the primary I'm talking about the coal in series with a fuel cell the secondary call lead what's left on connected on one end and I was arcing it on either of the other call that was in series terminals and with a right Arc a 12 volt light will light and the amp draw only went up 20 ma.
     I do believe this circuit should be used to convert energy and not for a fuel cell I think the fuel cell is connected too soon in the circuit I also think this should be a wireless system with that being said you could now draw and imaginary circuit were they fire stats in resonance in the second goes to the fuel cell I believe this will give you the full 360 Degrees rather than the 180 degrees I feel like I am getting now. Sorry sorry about the typos it is a text-to-speech cell phone error it's either that or not posted off sitting in the parking lot of a doctor's office. I have many formulas I have gathered up over a great deal of time reading and researching I will scan these formulas if anyone is interested it is the master of resonance equations that I have put together one by one and they are all correct. I'll have all sorts of equations I'm about five sheets of paper I have taped on my wall if anyone wants them feel free to ask and I will post them somewhere here I will post them anyways like her own when I get time and if anyone has any problems with a formulas I will also post a how so you use them and anyone here that stuff used on the equations will no longer be confused cuz I will break it down really simple so everyone can understand how the form was work. Also also Stanley mayor has some form of in his patent and he says the dielectric properties of water is 78 arms meaning that is the capacitance reactance is 78 ohms with that being said it would only be true if the inductance reactance was also 78 ohms. Stanley walk Stanley walked around preaching 20000 cycles per second so with this and the end credits and capacitance reactance we are now able to check they circuit to see if it reacts is 78 or Twenty Thousand cycles per second using these formulas. I will I will upload a few videos on how to use these formulas to make it even simpler so if you've never done it before I will tell you now it's nothing don't sweat it these are very simple equations that I will teach you how to do.
    One last night Tesla has some missing equations and I believe we can find them. If you if you search for Tesla on Wikipedia you will see patents in those patents you will see a energy converter that is on a round ring and in another patent you will see how he supplied the voltage with a twin to horse call where it is not labeled that.  it is possible whoever stole the patents did not realize how powerful this patent was I think it is a leak. I will end this post saying Tesla's low voltage primary was very fine wire and the secondary was very coarse and it was wired on the outer side of the fine wire on a toroid. This is completely backwards from the Tesla coil. Also he does everything in sets of two's there is many different ways to hook the coils on the toroid as explained in the patent. Hey refers to this as a energy conversion machine that can be used in multiple ways and he Powers it with a twin horse coil. This is why I was saying one horse can pull 8000 lb into horse can pull 40,000 lb if you can understand that pick a pair that with these dual coils then you can make the equation they do not know enough to even attempt it at this time because all of these energy converting devices uses radio frequencies and not anything below 100 Hertz.
  21. Steve
    Hi Hydrocars,
    If i understand you well, you say that the Tesla setup is creating more energy then you put in?
    Its like opening a gateway?
  22. Hydrocars
    Radiant energy Steve. I'm working threw resonance and Tesla's building resonator is related, I'm surprised what can be done with just 1.5 volts at the moment. I'm in deep research at this time. I will share all my findings.
    I can't wait to see someone confirm this above circuit.
  23. Steve
    You put 1 volt in that mini Tesla?
  24. Hydrocars
    I doubt that, probably 35 I didn't measure, I haven't took anybmeasurements, I was so excited about hydrogen production with 1 wire. The wattage had to be low. I don't care if it was a hundred amps of current I don't care if it was 300 I'm just impressed with someone wire production...
  25. tektrical
    I don't think the circuit has to be confirmed; it's basically an energy harvesting circuit with Stan's inductor added in.  But I am working on it.  What I'll try is one wire from a CFL.
    https://www.google.com/search?q=energy%20harvesting%20circuit%20schematic&tbm=isch&tbs=rimg%3ACTeg3kEWk9vNIkA1AVOWongdwJWf69n6mhmW0i0-NLNnC3J2roxcvMy3eHh6Wf1tQW-gr684-SMLaSbiqkSdWOBVNvAYyEaXJ1akKhIJNQFTlqJ4HcAROL3DbHvMvGYqEgmVn-vZ-poZlhHp3AAVUHTkhCoSCdItPjSzZwtyEY0A7VZpteKJKhIJdq6MXLzMt3gRjEalN3_1s5zsqEgl4eln9bUFvoBF5dzDQphe9LSoSCa-vOPkjC2kmEbrlIae4jymuKhIJ4qpEnVjgVTYRjEalN3_1s5zsqEgnwGMhGlydWpBF5FlxxoEA6eGFlq9z-ygC07w&client=ms-android-verizon&hl=en&ved=0CBIQuIIBahcKEwi4ms-ktZbpAhUAAAAAHQAAAAAQCQ&biw=360&bih=511#imgrc=cPEsO9LMyspFzM,,
