How to get more power out of HHO to run an engine
Started by unknown · · 5 posts · last reply 15 January 2012
    Please read and comment on this....
    Source: http://www.project.nsearch.com/forum/topics/how-to-run-your-car-or-truck
    Please keep an open mind after you realize that most of it is Fast Freddy stuff.
    At the bottum i found the following note:
    Hydroxy borrows energy to seperate the atoms, borrows more energy to put back the same volume you put in----no gain. Now compress the H2 and O2 to 80 psi adding steam to bond the molecules while being ionized by the positive charged case, and the extra atmospheric thermal ionic transferance formulates an new energy molecule in the form of plasma. When exposed to the vacuum of the combustion chamber during the intake stroke, it expodetially expands, and when recompressed during the compression stroke and ignited by the spark plug causes a massive combustion more than enough needed to fulley power any combustion engine...
  2. Dave
    Steve, I just had time to read through it, I hope it's real haha
    What kind of dense gas do you think they are talking about? If they are adding in negative ions they would attach themselves to the oxygen, would the gas still be combustible at this point?
    Or maybe you have a different opinion?  :)
  3. Bubz
    I don't care too much for Freddy's theories, although, he did show what seemed to be his truck running fairly well with a simple and cheap modification to the vehicle. It appeared to have run on HHO of typical popular designs of recent times. What is not well known is he also added some gasoline to the water. At first, your knee jerk reaction would be to dismiss him altogether, but, when you look deeper into what he was doing, you may be able to realize he had done something old yet new and possibly very inexpensive to build using only the technology most of us have been using already for our own tests and so on. He had solved a problem that has plagued HHO researchers for years by simply adding a little gasoline to the mix.
    You see? What Fast Freddy may have done is most ingenious! What may have come off as a blunder could be the revolutionary design all of us have been searching for. A milestone in the history of HHO research. I hate making predictions, but, I think this may catch on soon and be a popular modification for HHO enthusiasts and alike. His design is easily replicated since he used the same ideas we have all been using for the past decade or more. He just changed a few parameters.
    Here is how it works... the cell is a typical "Stan Meyer" type multi-tubular cell, with a PWM and all the other doodads like pressure valves and flashback arrests. Contents of the cell consist of 80% water and 20% gasoline. Freddy claimed 2%. But, 80% water is still damn good on savings in gasoline. Remember, gasoline engines can run very efficiently on gasoline vapors, reducing the consumption by at least 80%. But the problem of overheating soon will overtake the engine without proper cooling such as water injection as used in the days of the war. On the other hand, HHO does not have enough energy to produce the same thermal output as gasoline, no matter how much we can cram in the cylinder before detonation. HHO simply does not have the energy to run any motor or engine at full throttle with a load in normal conditions. In short, HHO has no torque. So, gasoline vapors are too hot, and HHO is too cool, but when we put the two together, things seem to work out just right. Hence, Fast Freddy's HHO, gasoline vapor, and water injection system. Basicly, it's a $500.00 DIY system that can save you 80% or more on your gas bill.
  4. Dave
    gasoline is much slower burning than Hho, so I see what your saying. That's why Stan had to slow down the burn rate. Mixing gas into the water could be interesting. I worry about the effects it would have on my cell housing. Gasoline is an ugly thing. Also how do you think the rate of gas to Hho would be controlled? Temp? I would think you would have to ad more gas to the water
  5. Bubz
    Freddy's design is rather archaic and there is little control over ratios and metering, but it works. Here is a link to a video with a similar design but without the cell. In the video, he uses a 50/50 ratio of water and gas. Notice also, later in the video, he blows through the reactor pipe, demonstrating how a resonant cavity works.
    http://www.youtube.com/watch?v=2-uj6O8_4Bg&feature=related
