harmonics discussion
Started by unknown · date unknown · 14 posts
Might it not be that the step charge waveform is nothing more then the steps you see on a waveform including harmonics?
Harmonic induced by chopping circuits,
3rd harmonic means you observe 3 peaks near amplitude of half sine wave,
5th harmonic means you observe 5 peaks in half wave .
harmonic disturb to capacitive current and inductive current ,
due to harmonic capacitive current increase and inductive current decrease
see 1:20
Look at the wave forms.
Are they not similar as Puharich wave forms?
The additional harmonics, Puharich says, cause the proton in the hydrogen atom TO ROTATE, further forcing the hydrogen to split from the oxygen.
The sine wave carrier converts to a rippled square wave pulse which reflects the RC time constant of water, and it is observed that the square wave contains higher order harmonics.
The wave form now automatically shifts to a form found to be the prime characteristic necessary for optimum efficiency in the electrolysis of water and illustrated in FIG. 11. In the wave form of FIG. 11, the fundamental carrier frequency, fc = 3980 Hz., and a harmonic modulation of the carrier is as follows:
1st Order Harmonic Modulation (OHM) = 7960 Hz.
2nd Order Harmonic Modulation (II OHM) = 15,920 Hz.
3rd Order Harmonic Modulation (III OHM) = 31,840 Hz.
4th Order Harmonic Modulation (IV OHM) = 63,690 Hz.
What is believed to be happening in this IV OHM effect is that each of the four apices of the tetrahedron water molecule is resonant to one of the four harmonics observed. It is believed that the combination of negative repulsive forces at the outer electrode with the resonant frequencies just described work together to shatter the water molecule into its component hydrogen and oxygen atoms (as gases). This deduction is based on the following observations of the process through a low power microscope. The hydrogen bubbles were seen to originate at the electrode rim, 4', of FIG. 3. The bubbles then moved in a very orderly `pearl chain` formation centripetally (like the spokes of a wheel) toward the center electrode, 1' of FIG. 3. FIG. 12 shows a top view of this effect.
All from Puharich -
Hello Steve
You think than we should add all the frequencies isolated from each other?
or you mean like Fm frequency modulation... you canachieve that with a pll too... but you need the modulation signal to be like a triangle ramp or sine....
meyer resonant scanning circuit is interesting but it can find lock and all but it only looks for nice frequencies if we modulate it it can create many harmonics...
all harmonics are super imposed, if you add them all together...
Sebosfato, i am not sure, but Ron somewhere wrote that you should put an AM radio close by your VIC.
The more noice you hear over a larger bandwidth, the better yr VIC works.....
For me, that sounds like a lot of harmonics.
Transmitted into the water, like a very very dirty AM transmitter.... -
Puharich claimed to have discovered a connection between all parts of the watermolecule as they seems all harmonic related with eachother.
So, if you hit the right base frequency and yr transformer is doing the harmonics, you automatically hit all components of the molecule.
Thats also probably what Bob Boyce once seen as effect with his crazy toroid.....
Creating harmonics.....and then try to transmitte them into yr waterbucket -
YOU SHOULD ASK THE RIGHT QUESTIONS!!!!!!!
I sometimes feel so stupid.
Look here what harmonics did to a CAPACITOR!!!!
Imaging a watercapacitor.......attachment_14551 Oberschwingungen-Zerstoerte-Kondensatoren.jpg
If you have worked with Bobs circuit or have his circuit and not performed this expieriment it is really neat... Bobs tunning method with the adding of the 3 harmonics as like a form of amplitude modulation will with a camera capture a square wave with 3 ripples on top...its rare and you have to take shot after shot of the scope with it in tune but eventually you will capture a square wave with those 3 ripples...i done it myself...its not seen with the naked eye and i dont have that picture anymore but it was facinating.
this sound like using also a magnetic field to allign the molecule to me...
i tried the radio... all i hear is the frequency i put into the vic... if the vic resonant frequency is high you will hear the gating at the radio even very low frequ...
you need am radio..
this happens because around the vic and cell there is a very high electric field being modulated and the antena capture that as its a strong enough signal...
did you saw my regard about using iron rods for example intead of copper to take the signal out of the transformer? to conduct also the magnetic field to the cell maybe...
dan danfor said the material of the electrodes should be 430...right? to conduct magnetic field... such say also horvath that magnetic field is said to be good for it...
so far in my opinion the creation of a transverse electromagnetic wave on the cell while geting it charged seems to be what is required... it must be short and powerfull enough to turn off the covalent bound of the milions of charged molecules at an instant of time...
there is a time for water such as there is for nitrogen to the population inversion will decay also there is a minimum electric field required for population inversion to take place...
anyone ever found this numbers for water?
i think i came across it but dont remember what paper or book was it...
i simulated with transmission lines and seemed to work the generation of nanopulses depends on the lengh and the impedance on the thickness and width...
however the voltage is limited to the supply voltage if load is matched... if its un matched the volatge across the load can be much higher... even with the charging coil across the load...
as i pointed some time ago inductors looks like an open circuit for short pulses.. thats why is called charging choke... it allows dc to charge but chokes the high frequency off...
http://patents.com/us-3617867.html
If you are interested in the proton this patent will tell you alot. -
Nice stuff. Never read anything like this type of tuning.
Well done!
is there anybody else having some ideas on the use of harmonics as being part of the Meyer VIC?
All signs for creating harmonics are in the VIC.
If you do revers engineering on what all transformer builders and switching power supply builders are doing, you end up with the VIC!
