Electronic unit
Started by unknown · · 8 posts
    Electronic unit
  2. outlawstc
    these are pages from a international patent of stans from 1992
    page one shows the basic layout of the control and driver circuit for a hydrogen gas fuel producing cell..
    the way i see it is no one will see results until they achieve a circuit such as this one..
    what is the variance and speed of change to the dielectric properties of water during the process???
    as well as how precise does one need to stay tuned to this never ending variance to achieve increase in production?
    FIGURE 1
    is a block diagram of an overall control circuit showing the inter relationship of sub- circuits the pulsing core and resonant cavity.
    (http://i82.photobucket.com/albums/j243/outlawstc/pic1.jpg)
    FIGURE 2
    shows a type of digital control means.. the type is determind by the goal.. for example a control means could be for sencing the need for acceleration in a automobile or a control means for controlling a home heating unit..
    (http://i82.photobucket.com/albums/j243/outlawstc/pic2.jpg)
    FIGURE 3
    shows a analog voltage generator
    (http://i82.photobucket.com/albums/j243/outlawstc/pic3.jpg)
    FIGURE 4
    is a voltage amplitude control circuit interconnected with the voltage generator and one side of the primary coil of the pulsing core.
    (http://i82.photobucket.com/albums/j243/outlawstc/pic4.jpg)
    FIGURE 5
    is the cell driver circuit that is connected with the opposite side of the primary coil of the pulsing core.
    (http://i82.photobucket.com/albums/j243/outlawstc/pic5.jpg)
    FIGURE 6,7,8,9
    relate to pulsing control means including
    FIGURE 6
    gated pulse frequency generator.
    (http://i82.photobucket.com/albums/j243/outlawstc/pic6.jpg)
    FIGURE  7
    a phase lock circuit
    (http://i82.photobucket.com/albums/j243/outlawstc/pic7.jpg)
    FIGURE 8
    resonant scanning circuit
    (http://i82.photobucket.com/albums/j243/outlawstc/pic8.jpg)
    FIGURE 9
    pulse indicator circuit
    (http://i82.photobucket.com/albums/j243/outlawstc/pic9.jpg)
    FIGURE 10
    shows the voltage intensifier circuit
    (http://i82.photobucket.com/albums/j243/outlawstc/pic10.jpg)
    FIGURE 11
    is the gas feedback control circuit
    (http://i82.photobucket.com/albums/j243/outlawstc/pic11.jpg)
    FIGURE 12
    adjustable frequency generator circuit.
    (http://i82.photobucket.com/albums/j243/outlawstc/pic12.jpg)
  3. Dankie
    Why dont you go ahead and do it and make the PLL or any pulser you may find more easy , learn ltspice and read about the PLL circuit . Many have made it work .
    You dont "HAVE TO" make a circuit such as this one to test out Stan's main ideas .
  4. outlawstc
    Donald
    check out figure 5 .. this is Stans methods of driving the primary coil gate.. this circuit is connected to the opposite end of primary (negative/ south)  notice theres a blocking diode there and there is a diode bridging north and south in opposite direction of the one gating to ground
    now check out figure 4 this one is the one that the primary's north side connects to..  Stan has it where he can switch the positive side of primary to either a strait connection to positive on the battery or this a variable amplitude control means. this means during pulsing amplitude of positives source can  variate  causing the oscillation of amplitude of primary's positives connection while controls grounds interaction though figure 5 cell drivers negative connection
    i wounder if tony being a electrical engineer could maybe throw some values in for the components and see if we can replicate this circuit.. it cant be to hard
  5. TonyWoodside
    A1 and A2 in the Digital Control circuit looks like they could be Multiplexer chips.
  6. outlawstc
    so what do you think tony? you and maybe some engineer buddys might be able to fill in the values of the components in this complete circuit??
  7. outlawstc
    im not sure what A1 and A2 are tony but i am pretty sure of the objective of  this specific digital control means..
    from what i can see this is what stan had in his distributor and that is how stan syncs  the rate of production to the  acceleration  needs in a car..
    the digital circuit   can be a simple manual controlled circuit for experimenting..  it doesnt need a digital circuit that is made to variate production to the means of a system, such as a automobile..
  8. Dankie
    Even if you asked an engineer what something is he probably wouldnt instantly know what it is , most engineers work with pic chips . Its not like , OMG I remember this wiring ... No engineer is gonna research anything for you unless you pay them for it .
    Not that hard ? Those can be anything ...
    Normally when you make something you ask yourself what should be done , then figure out how to do it with the chips wich sometimes means learning the chips , when you dont understand the chip you read about it . Simple as that .
    Triangle in the triangle , square in the square , round in the round .
    Things would go faster if you would go by this method .
