Dissolve exhaust gasses in water for electrolyte - idea?
Started by unknown · · 7 posts · last reply 27 October 2009
  1. Logic
    This is just an idea that perhaps someone will test.
    (Is ther a better place to post this?)
    Dissolve exhaust gas in water and see how it does as an electrolyte:
    CO2 + H2O ? H2CO3 (Carbonic acid) + dissolved CO2  (This is a weak acid)
    C + H2O = CO (burns) + H2
    Dissolved O2 (O2 will displace air: a good thing)
    Thats about it; if you have a 3 way cat.
    Without you also get:
    NOx + H2O = 4 HNO3 (nitric acid) via a long process that includes HNO2, HNO3 and NO
    CO + H2O = HCOOH (formic acid) + dissolved CO  (This is a weak acid)
    Unburned HCs + H2O = ??? (Didnt someone test a mixture of fuel and water in a cell and get good results?)
    You will also get a small bit of hydrogen sulfide which dissolves in water to make a solution that is weakly acidic.
    Perhaps this devil's brew is by some fluke the ideal electrolyte and gives great gass production and cleans up our exhaust a little!  :D
    What exactly the gas will consist of is a damn good question!  :)
    Certainly H2 and O2.
    Perhaps CO (burns)
    Possibly Nitrogen.  :(
    You may end up with carbon on the electrodes, which may or may not be good.
    The gass hopefully will contain CO. (burns)
    A simple test by bubbling exhaust through a bucket of water and using it in a cell would be interesting.
    No idea how fast the solutes will be used up or how much of each will be in solution.  ???
    So what do you think??
    http://mattson.creighton.edu/H2S/H2S_Info.html
    http://wiki.answers.com/Q/Is_carbon_monoxide_a_acid_or_alkaline_solution
    http://en.wikipedia.org/wiki/Carbon_monoxide#Atmospheric_presence
    http://en.wikipedia.org/wiki/Nitrogen_oxide
    http://en.wikipedia.org/wiki/Carbonic_acid
  2. Logic
    Lets run on ammonia.
  4. Logic
    ....  Ke?  ??? (ala: Faulty Towers)
    Nitrogen and hydrogen = ammonia
  6. Logic
    http://www.ecospec.com/index.html
    Question:
    Has anyone bothered to test the gas coming out the electrolyser?
    Why are they not feeding it to the engine?
  7. sebosfato
    logic
    nice one
    try it please... ;D
    thanks
