Cold Fusion demonstrated very successfully
Started by unknown · date unknown · 3 posts
  1. Logic
  2. russrHHO
    He probably could have made fusion work by following the tech details of John Keely from late 1800's. Resonance phenomena with frequencies and ratios applied, in his 114 work shop inventions. He could make like poles of magnets attract, get 51 inches of mercury on vacuum gauge with hollow sphere, generate 23,000lbs water vapor pressure in 15 seconds, built self running fluid motor using water hammer pulses from 4 way shock valves, created lift effect demonstrations against gravity with vibrations applied, etc. Visitors signed documents as being present during some demonstrations. Reference books available for those not knowing about this research physicist. Also The Snell Manuscript from S.V.P. -- summary of Keely's 3 lab books. The Keely Motor Company Philadelphia 1865-1899.
  3. russrHHO
    John Keely tech documents from late 1800's showed bench tests regarding molecules that could be controlled with frequencies and ratios. Such as like poles of magnets attracting, easy separation of water into fuel gases by vibrations , gravity control of weights with visitors signing documents witnessing things. The history books show just only deception done, by this experimental physicist. The modern cold fusion tests could be greatly advanced by researching the documents MADE by John Keely. He also discovered heavy water, - Deuterium as left over substance in his cavity resonator sphere. His methodology is the CONTROLLING influence that can be applied to this Cold Fusion. (There is no set up and wait for proper reaction needed.) Purchased material available from Mr. Pond of S.V.P.
