Bob Beck Blood Electrifier
Started by unknown · date unknown · 36 posts
  1. Donaldwfc
    http://www.educate-yourself.org/be/beckelectrifierschematicandparts.shtml
    (http://www.educate-yourself.org/be/schematicelectrifier.JPG)
    (http://www.educate-yourself.org/be/4electrifierparts.JPG)
  2. outlawstc
    here is his lecture pdf..  it has the newer solid state version needing no relay..
    (http://i82.photobucket.com/albums/j243/outlawstc/Picture012.jpg)
  3. Donaldwfc
    have you tried it on yourself for a few months yet?
    have any pictures of the circuit, i just started gathering up my parts again, but i'll have to get a few more components
  4. outlawstc
    i had to use some resistors in series and i used some that are bigger then needed.. the circuit diagram for this one which i think is using a lm358 op amp is the the link i posted above which are the papers bob beck would hand out at lectures..
    (http://i82.photobucket.com/albums/j243/outlawstc/Picture013.jpg)
  5. outlawstc
    i havent used it in a while because of my recreational practices.. not only that but also when i was using it the job i was doing at the time sealcoating parking lots/ asphalt patching i think breathing the fumes and doing it was toxifying me.. you cannot eat garlic , take meds, herbs, be be exposed to toxins or drink when using it.. due to your red blood cell will be over toxified due to the effect of dilating it to where its more absorbing to such elements..
    i used the rodin coil for like 3 days projecting predetermined frequency for different organs , it put me in a state of no hunger for like a week.. i have had lower back problems with it and some self adjusting i have notice a change in my back for the good.. . kinda weird droped like 5 lbs but now i feel like a champ..  i find eating fresh cayenne peppers makes you drink way more water and is a good influence for detoxing.. very effective if you stay consistent..
    i need to start using it again..  mine also has the colloidal silver maker built in the same device..
  6. Leon
    Love to join here to build the Bob Beck Blood Electrifier but it is to hard for me to read the schematics below.  I've found this 'as is' video to make the device on a breadboard. I have to search and collect all the components first.
    [youtube]http://www.youtube.com/watch?v=1YZnZmTQKPg[/youtube]
  7. outlawstc
    here is a picture of the latest one bob made.. i also attached a pdf of his lecture papers (40 some odd pages)
    This circuit also shows the schematic of his colloidal silver generator..
    (http://i82.photobucket.com/albums/j243/outlawstc/bobbeckcircuit.jpg)
     BobBeckPaper_backup2.pdf
  8. Donaldwfc
    thanks outlaw, i will take a good look at the new circuit too, i have the relay and some other parts for the first one, but i'll see what i can build easier, since i will need some new parts too
  9. outlawstc
    no problem Donald.  i strongly suggest the one i have posted for the fact it requires less power to operate.. the one with a relay requires batteries for switching the relay on and off and then it needs the batterys for sending the microcurrents into the body.. my circuit u see in the pic above has about 5 resistors that are uneeded.. i didnt have the right value and had to put them in series..
  10. Donaldwfc
    outlaw, that circuit shows 3 connections to the 3.5 mm jack, i have redrawn the circuit and now i am wondering which connections go to the skin
    from pin 7 it branches off into the pot circuit and the LED circuit, but i dont see what the finial connection to 3 is
    i assume connection 1 and connection 2 go to the skin, but what does connection 3 do?
    (http://img.photobucket.com/albums/v81/bigbuba/Picture1-7.png)
  11. outlawstc
    Pin 3 is the indicator part of the circuit.. When my electrodes are wet and i touch the together is will dead short and flicker the led red and green.. The flicker is the alternation of current to the led.. More or less he has it on there to help know when to change the batteries because it will dim out during dead short if the voltage isnt strong enough.. I connected with pin 1 or 2.. not sure whcih one.. The device is at my moms house let me look at some pictures and see if i can tell you which side i hooked it to.
  12. outlawstc
    I think what it was is they make head phone jacks with 3 channels.. The female jack being a 3 channel. and the male being a 2 channel for bob becks device.. 1 channel of the 2 channel will also connect to pin 3 in the jack itself.
  13. Donaldwfc
    so pin 3 either goes to pin 1 or pin 2 when the jack is plugged in, otherwise it's off, i guess simple testing would get it working properly
  14. outlawstc
    Yea im not sure to be honest. Mine is not with me at the moment so i cant crack it open to take a look.
  15. Leon
    I've got the components and put it all together on the breadboard. I followed the video and it was very easy to build. I came also at the point how to translate the 3 wires into 2 for the electrodes for your arm. I took the ground wire and put it on one of the two others. There is only 1 combination that works, so easy to find. I had my first session today for 15 minutes like the schematics that they recommend on there website. http://www.unleashhealth.com/store/booklet_preview.html Let you all know how it goes later on.
    (http://www.sumopaint.com/files/images800/ifbbbfzrmmcpxgfr.jpg)
  16. Donaldwfc
    very nice! i should order my components and get this done, keep us updated on how it feels, if his thing works like he says then it can make us all healthier!
  17. Leon
    While I'm using the device I became i little confused. I measured the Hz output and it was 40 Hz.
    40 Hz is the most save value to use the system but I wanted the more stronger setting like 4 Hz. I replaced the little 103 ceramic capacitor 0.1 uF, with a electrolytic capacitor 0.1 uF, and bingo I got the 4 Hz running. The only thing that is not good is the voltage output. It should be 27 volt on the two output leads. My batteries are absolutely full but I get only 5 to 6 volt max. That is not good enough, anybody a suggestion? I used the device for some days and I noticed noting on my body, just a slight tingle on the skin, noting more. The demonstration video's showing a much stronger appearance, the users must temper the voltage always with the potentiometer. I saw the fingers of somebody react in the rhythm of the 4 Hz.
    (http://www.sumopaint.com/files/images800/igeiffzgtjclliei.jpg)
  18. Steve
    Just put it on 7,8h till 8 hz, Knovos. Thats a frequency that your body uses for regeneration.
    Becarefull with other frequencys. Read on google for Rife (royal rife) They have lists of frequencys.
  19. Donaldwfc
    if you are not getting the 27 volts then check the resistance... use the ohm meter to check while you play with the pot and compare to ohms law, and the volt meter to compare too
  20. Leon
    Thanks Donaldwfc. I replaced 3 resistors and both a new potentiometer. The device works ok now. I have to temper because the highest setting is way to strong! Now I must start all over again with the schematic, just a bad start.
    Thats a great link Steve. I did not know there is so much research on micro electro healing. All those frequencies and so many different diseases. There is a lot more to explore but I will first stick to the normal Bob Beck method with 4 Hz.
    Knovos
  21. Donaldwfc
    I ordered my parts from digikey,  should be here in a few days or a week or so, then i'll build it!
  22. Leon
    Good luck with the building Donaldwfc. I ordered some extra components too for making the design with the one 9volt battery. Should be nice to have a device which is as small as possible. I have also ordered stuff  to build the Bob Beck magnetic pulser. Another device which have great healing possibilities also, its one of the 4 components of the Bob Beck protocol.
  23. outlawstc
    When it comes to bob beck's magnetic pulse i think it has been surpassed by Marko Rodin and Jamie Buturff.. both of them have made a unique style of coils which seem as if they would be benificial for inducing pulses into the body..
    Jamie Buturffs coil seems like a good one to replicate.. He calls is a Vesh 432.. he says the 432hz is interrelated with the solfeggio frequencys which are known for energetic healing..
    (http://i82.photobucket.com/albums/j243/outlawstc/vesh432.jpg)
    (http://i82.photobucket.com/albums/j243/outlawstc/vesh432-2.jpg)
                            If  all matter is energy in vibration (E=MC^2), then what is the frequency  of that vibration? It's all harmonics of the A=432Hz - not 440 Hurts.  I've seen too many people experience wonderful results on my coils and  harmonic sounds to know any different. The lower octaves are 216 and  108. See anything familiar with these numbers?
     the interesting thing about the Solfeggio  frequencies is they are all harmonically separated by the 432 and are a  trinity of family number groups 1,7,4 - 2,8,5 - and 3,9,6. For example,  take the first solfeggio of 396 and the four...th  solfeggio which is 639, one digit shifted to the right and the same  number group. If you subtract the two numbers you get 243 which is 432  shifted one digit to the right. This applies to all 3 solfeggio number  groups!
    You see, the solfeggio is a code - one part unlocks the  proper frequency of natural vibration but also gives us the harmonic  interval of the rhythm that accompanies the 432 frequency in the 1,7,4  - 2,8,5 - and 3,9,6. This is the symphonic code of the universe!
     The solfeggio is a beautiful code that gives us so much more
  24. Leon
    That is a beautiful made device what you showing there. I have heard from a rodin coil but not the name Jamie Buturff. I picked the Bob Beck device because of the big community that's behind there using his devices. They are building other variations these days, like
    http://www.members.optusnet.com.au/~aklemens/
    Concerning the pulser device it is the best way to build something that works and make later on some improvements if necessary. I 'l keep that 432Hz in mind. Thanks.
  25. outlawstc
    a picture of mine
    (http://i82.photobucket.com/albums/j243/outlawstc/101_1024.jpg)
