Ambient airgasprocessor setup
Started by unknown · · 12 posts
Ambient airgasprocessor setup. -
Here is a patent about creating ion wind.
That is a way to ionize the ambient air.
My first test will be with a similair device.
My setup will be like this one..
Another patention patent 2.pdf
Manual with schematics
ion generator schematics.pdf
A goldmine of info! That picture Steve posted above is priceless too! Don't you think? Thank you Steve! I especially like the ion canon pdf. -
Thanks Bubz
I already made such an ion wind gun....
http://www.ionizationx.com/index.php/topic,1265.msg15000.html#msg15000
I am designing my own ion wind generator .
My circuit will incorporate a flyback transformer that I make myself with some stainless steel bobbin I have I will cut the middle an d wrap a primary on top and see what happens .
I will then allow the gas to flow in the middle of wheree should be a core and feed back the HV wire in itself .
If It works I have also a deisng , a succession of +-+-+- and finished by - in connected in series in the tube but parallel to eachother pareallel with eachother where the optimum frequency related to gap space is found for maximum acceleration and current is kept rolling in the same direction with a freewheel diode -
Excellent ideas Dankie! I was reviewing the info Steve posted and I noticed the intake ionizing system utilized the LED arrays. This is not a big deal other than finding who sells these. Any Ideas? -
Im glad you like the idea , it is more a logical thing , I see the core I say hey , theres a bunch of magnetic lines in the middle , why not use this as a gas processor and insert some HV . -
Meyer gas processor creates positive ions not negative ions. Gas processor is the key of meyer process. Attached an extract from meyer patents.. I'm glad to annunce that in the next days I present new water gas stone stove using meyer process inside.attachment_10825 meyer_patent_2067735.png
