321 Stainless Steel
Started by unknown · · 2 posts
  1. CarbedNotch
    Type 321 contains titanium for greater resistance to corrosion and pitting. Excellent corrosion resistance and a seamless, smooth bore make it suitable fpr all types of applications. Tubing may be flared and is compatible with conventional compression or flare fittings. Also known as "aircraft tubing" because of its corrosion resistance and higher pressure rating.
    What  do you guys know about 321 in the WFC?
  2. Donaldwfc
    Is is cheaper than 304? Stan has the lab analysis report on 304 saying it'll last 10 000 years, so unless it is just as good as 304 AND cheaper, then we would be breaking the law of economics to bother with it ;)
