Stepping in.
Started by unknown · · 10 posts · last reply 12 September 2024
  1. Hydrocars
    I've not the change to read any post here or elsewhere, nor even surf the web for over 8 years now. Have you boys Cracked it yet? Have any of you yet to Master this technology? Answer quick as I have to Reply Quick then leave fast. In days to come.
  2. Hydrocars
    Is their a reason I have no replies? I feel as if I'm being ignored on the very website that I created. If I did not have A purpose I wouldn't have bothered wasting anyone's time. I'm unsure to why I have no replies but it saddens me to see this. What is going on with you guys? If I have done something that was disrespectful to cause this please let me know, tell me directly here.
    Hi Brian,
    Nice to see you back here.
    On most hydrogen forums and new energyforums it is quiet.
    Are you back trying to figure Meyer out?
    Cheers!
    As far as i know, nobody really figured Meyer out.
    No massive hydrogen production for little power.
  5. Hydrocars
    Forgive me I only have a brief moment I will lightly touch bases as I do not have time but will try anyways I will try to come update later
    It is known that if you have two separated containers insulated perhaps plastic containers one can be charged with a Van de Graaff static lock charge positive the other container negative the water carries opposite charges about injection into the engine through the intake valve the water becomes a fuel in this manner and ignites under compression or the spark exist.
    Stanley mayor forgive me for spelling as text to speech was using a pressurized fuel cell and ionizing the gas where they have voltage DC pulse where higher the pressure in the fuel cell they more magnetic properties they gas would take on and they greater the charge the higher the pressure. His EPG r e e g I forget which one he calls it the circular worm like ordale with coals all around it was a example the reason I point that out is to ensure you and you can look at the patent dates he was using a recirculating pump as the hydroxy was ionized and left the high pressure fuel cell it was recirculated back into the fuel cell so that they high voltage ionization such as what's used on those lifter UFOs could further charge the gas which a few years ago I had made a statement my fuel cell blew up and it was sparking I could not figure out why that's what I was doing that day and also I remember a flame about 24 in in length and cannot figure out what I had done so I had made an improper conclusion that it was due to contamination but it was I am us gas that I had witnessed it just recently had figured this out.
    The electron extraction used on the oxygen electron to pluck It Off is used with photo transistors that is usually used to isolate circuits they charge from the battery/ generator to the fuel cell for production of gas is Switched Off at the same time the electron extraction to consume the electron from the oxygen atom is switched on and this is repeated very rapidly and also done during the time the pressurized hydrogen has a higher voltage applied to it and becoming one of the three different types of hydrogen elements I forget the three but you could look them up some of them is already overreactive some carry extra electrons some carry neutrons something to not this is related to Stanley's hydrogen proton accelerator and this is very high tech science that has been overlooked but it is there. Hydrogen gas does become magnetic the higher the pressure the more magnetic the faster it moves the more magnetic the oxygen atom can be stripped of its electron and it can become a nuclear unstable gas ion or there is other words that has left my memory to explain the different types of combinations a single atom can become for example I will throw this out there how did you could be called a tri-top gas that is one of the three and I'm sure I got that wrong but I have not rehearsed posting this only going off the top of my head Trigon three different types of hydrogen I forget what you call a atom with an extra unknown number of added electrons or neutrons but they all become Radioactive all this technology is very real other gases was also introduced into the cell although it is not required and not important but the gas is that was introduced was gases that had already been burned and this father helps slow the burn rate of the hydrogen down but by the time it goes through the electronic extraction circuit I guess ionizing circuit for the hydrogen it's really not needed and if you look at the output comparement when that you do get something to compare to you will quickly learn that one gallon of water is equal to like 70,000 barrels of oil so it does not take very much hydroxy gas to make this work when it is understood in other words that six leaders are whatever you was producing could have ran your motor you're working on that day for probably a number of weeks just from that small amount of gas only after it has went through the gas accelerators and ionizing processes it is not so much the voltage intensify your circuit although that is very real and they water does become a capacitor but that is a cold process and the electrodes are Teflon coated and it works from a sort of van d graph type deal and there is also indeed another electronic circuit where a choke is placed in series with a fuel cell with a capacitor shunted at its beginning and that is a second part but frequency if you look at the contactor coil on a residential air conditioner system you'll see the 24 volt contactor magnetize the contact using alternating current Faraday used what was called a interrupter circuit Tesla removed the circuit and used normal 60 HZ the Tesla coil has been shadowed as Tesla is the one that actually removed the capacitor from the primary coil and added it to the secondary and realized it could be tuned only after the Irish preacher discovered the Step up Transformer as Faraday only they step over isolation Tesla took the spark gap machine and I would also like to add using a spark gout to transmit is illegal and prohibited but Tesla used the spark gap on what Faraday and the preacher was working and added a secondary circuit that appears to be stan circuit. My time is very limited here today but I will say they spark gap light bulb that admitted such a terrible sound was solved by a tank circuit filter that you need to have in your crosshairs. If and for those that do not know and I will just throw this out there the third side of a triangle is the first side squared plus the second side squared that equals the third side squared and then you take the sum you got in square of these third side and find the square root and that is your answer. Henry's Times capacitance sum squared * pi*2 then you divide all of that some by the number one and you get the frequency
  6. Hydrocars
    And I will add when I was playing with my fuel cell I had to exploded it inside itself luckily it did not bust this was years ago and it did seem like I had some baking soda contaminated yet but I had used a high voltage DC coil it was charging the gas that had some already burnt gas mixed in it and I had a flame but shoot out of my little torch nozzle that I had built and the flame was about 2 ft in length and what was so amazing as to me the entire length of the flame it was very narrow and there was a flame from the tip of the nozzle and they flame continued for about 2 foot it was the narrowest longest flame I had ever seen in my life and they Tails coming from the flame was the same as a temp as it was the end it was it was the strangest flame I have ever seen it was almost like a liquid gas flame it did not feather out and widen as it got further away from the tip it stayed narrow from start to end it looked like a flamethrowing machine all I was using was water possibly baking soda but the main thing was I had ionized gas but my cell blew up I don't know if there was some kind of unstable oxygen in the tank that caused it when it back flashed but I got agitated and just let the cell set there and I noticed a lot of glitter like sparkling on the cell and you can hear it popping like it was electrically charged and I mentioned this to you Stevie years ago I don't know if you remember but that is what had happened and I am just now putting all this together
  7. Hydrocars
    The hydrogen element has three isotopes: hydrogen, deuterium, and tritium. We each have a single proton (Z = 1), but the number of their neutrons is different.
  8. Hydrocars
     To whomever is reading these replies, Please Be informed that I am very very sorry for the Jibberish way of wording. When my Replies come out that was it is because I am using a Cell phone to reply and I have a choice of Making No reply at all, or making a Jibberish one like the above. I'm actually on a laptop at the moment, I really dont want to state where exactly I'm at. But yes I can type and word things properly, and I do apologize.
       I will get back to you shortly, but I will leave you with a TIP. You do not have to use a Driver moter to spin the alternator. The Circuit in the schematics of the VIC, well, just imagine the ROTOR (the part that Rotates) Being the CHOKE. and Imagine a SECOND alternator being the other tunable Choke. Now you guys think on that! and again, you do not need a heavy Driver moter (To spin or turn the Alternator Moter) And You do have to keep the hydrogen under Pressure before you are able to alter the hydrogen into a ISOTOP. Google what Isotop is. The Infrared Transistor, (an isolation Technique) Is Used for Extracting the electron from the Oxygen (Creating an Oxygen Isotop) Please Copy this information immediatly and save it to a folder on your computer while you have the chance to do so, Just incase something happens to this website. Keep this information quite for as long as you can and do not go repeating it to everyone, I say this because it will give more researchers the time to copy this information so that they can make success. I say give it atleast 3 months before you spread any of this information. I have more, but my time is limited. I do apologize for the Jibberish. 2 tanks of water both seperated, vand dee static graaf charge one positive, one negative with them both isolated from each other (like the water drop generator) That water when injected together is Fuel. That last part was off topic. The Gas on the Stan part, It has to be electronicly Altered and become Radioactive Isotopes before it will work, and It is not hard. Go get you a colored TV coil and that should do it. The Electron Extraction is nothing more than a Normal Tungston Light of any6. kind will do, the photo transistor (an ic chip with 4 legs) 2 of those should get you by. I might post a video or 2 later if I get time.
    Edited in, (also Diodes are used for Generating Frequencies) Since they have a cut on threshold and off. A diode can and Will Generate on and off cycling just like a Frequency Generator. One of the First was a horizontal Glass Tube about 4 inches long, With Metal Shavings inside it, under a Partial Vacuum). At certain Times, electrons would flow threw the Closley Placed Shavings activing as a Switch. This was used in the Very very Early Birth of electronics. There is a reason 2 diodes are connected to each other, one backwards from the other. (They are creating a switching signal) The diode stan used has one of the Lowest threshold voltage, it was around .4 volts, I forget the exact, but thats pretty close.
  9. Hydrocars
    Are any of you guys following me? Hydrogen has three isotopes you have to use a particle accelerator to create these isotopes that's what the EPG what's doing he had hydrogen gas amongst other solids and metal dust particles mixed together to create that circular device in which the gas pump was in its middle as the higher the pressure per square inch the stronger the magnetic field the hydrogen isotope could maintain and would hold this field like a capacitor are any of you following this? I do apologize for the very quick reply I have switched my speech to text to a more proper application and try to keep it updated I am very busy at this moment if anyone has any questions about anything I have said feel free to ask and I will clear up whatever I can.
  10. tur55
    We don't have a particle accelerator.
    What are you talking about?
