Stan Meyer: What is high voltage in the hydrogen and oxygen generator
Started by unknown · · 10 posts · last reply 2 September 2009
    Patentnr.: 4798661
    What is high voltage accoording to Stan Meyer.
    In this patent he names everything above 2V high voltage!
    In the voltage schematic, Stan showed different levels:
    L1 = 2volt
    L2 = 4volt
    L3 = 6volt
    L4 = 8volt
    L5 = 10volt
    L6 = 12volt
    Ln = ?
    He is reducing amp flow by way of limiting the time that the plates get their voltage and amp. A pulsating system.
    The reason for doing that is accoording to Stan, that he doesnt want the voltage to drop, as soon as amps kick in and a dead short condition comes up........
    What do you people think of this.
     4798661.pdf attachment_3797 attachment_3799 attachment_3801 attachment_3803 attachment_3805 attachment_3807 high voltage.JPG high voltage 1.JPG high voltage 2.JPG high voltage 3.JPG high voltage 4 voltage schema.JPG high voltage 5.JPG
    Then Stan continues:
    He uses the blocking diode for some purposes:
    It must eliminate:
    1. stray electrons
    2. shorts
    3. variances,
    4. spurious signals
    5. BLOCKING BEMF or back-electromagnetic force
    He continues:
    The advantages of raising the amplitude of the pulses accoording to raising production og hydrogen:
    The dual pulse system bring the upper limite to 5.5V or L3 in the schematic of figure 8.
    Next step
    The Stan is doing someting strange. Instead of connecting all plates or tube in parallel, he just switches between every plate of tube, so that one 1 is connected at the time. This would bring the upper voltage limite to 7Volts
    See attachements
    The next level:
    Hooking up a resistor in line with the negative tube.
    This will raise the limite of voltage to 8.5Volts.
    The resistor will block electron flow, which sounds ok to me.
    Then he states that the voltage over the tubes is not effected by this resistor....hmmmmmmm not sure on that.
    Then he states: In the generation of the hydrogen and oxygen gasses to an INFINITE limit, as yet not fully appriciated???? , the upper level of amplitude of the voltage is removed with utilization of the electron inhibitor (resisitor) of fig. 7, which is a sandwich resistor.
  5. WaytoGo
    Yes, this is a big question.
    I heard Stan says in a video the wfc operates on 0 - 2000 Volts,
    I have also read that you need at least 1500 Volts to start the molecular ringing.
    Kilovolt and milliamp pulses with twenty thousand cycles across the excitors is said to shake the molecules apart.
    The alternator could have been used as a "hertz machine" and combined with a pulse circuit  it may reach 20.000 Hz
    He says he is doing the exactly opposite of the electrolysis prosess.
    Maybe he was taking OUT electrones so the water molecule collapsed?..
    He says he is doing the exactly opposite of the electrolysis proses.
    Maybe he was taking OUT electrons so the water molecule collapsed?..
    Thats an interesting question. How to extract electrons from water, without the molecules being aligned?
    For sure, there is always an potential of voltage in water, but the current is pretty low.
    The hydrogen atoms are always swapping oxygen atoms, so electrons must be floating as well time from time.
    So, a pulsing circuit with an electron consuming device attached to electrodes would do the job, i ll guess.
    Anybody any suggestions?
  7. Dankie
    Does the EEC have a diode , I dont remember ...
  8. Alan
    The electrons were taken out of h2o but not extracted from the wfc, it contributes to further dissociation by colliding with other h2o and / or forming h2 and o2. I think this can be called ionization by collision.
    If I remember correctly, in the NZ lecture he said an EEC on the wfc was not recommended.
    The free floating electrons are used to create o2 and h2 from the single atoms, and to dissociate h2o like regular electrolysis:
    The liberated and moving atoms (having missing electrons) regain or capture the free floating
    electrons
    once applied voltage is switched-off during pulsing operations.
    Subjecting or exposing the water molecule to even higher voltage levels causes the liberated atoms to
    go into a "state" of gas ionization.
    Each liberated atom taking-on its own "net" electrical charge.
    The ionized atoms along with free floating negative charged electrons are, now, deflected (pulsing electrical
    voltage fields of opposite polarity) through the  Electrical Polarization Process … imparting or
    superimposing a second physical-force (particle-impact) unto the electrically charged water bath. (electrolysis by reaction of e- with h2o)
    Oscillation (back and forth movement) of electrically charged particles by way of voltage deflection is
    hereinafter called "Resonant Action", as illustrated in Figure (1-10).
    Applied together, electrical forces (TT') and (UU'), now, causes these moving electrically charged particles to
    superimpose a physical impact unto electrical polarization process (160), as shown in (170) of Figure (3-
    25) ... thereby, increasing gas-yield (88) still further.
  9. WaytoGo
    Okay, Alan you have a good point, but if the electrons was taken out of the water and not the wfc... was a separate water container used for this purpose?..
    Anyway i tested a cell with PDC and a LED as a "amp consuming device".. only five or six volts.. i am glad i did, cell was completely steady with no amp climbing on the multimeter. ( when i took off the LED the amp where climbing slow up.
    Have also tyred AC and it is making extremely amounts of Hydrogen/ Oxygen from ca 180 Volt and up, but water is getting hot after a while and that is not what Stanley did..
    So AC or DC or PDC is making more or less heat if you make a lot of gas in straight clean tapwater whatever you do.
    But i found an "scientific article" sometime ago and wrote something important down : "Much heat is released when hydrogene and oxygen recombine to form water."
    Aha, so this is where the heat is coming from..I believed it was coming from the amps.. How did Stan keep the gasses apart in the wfc so he could build up the pressure and keep it "cold"?.. Even if he used no amps, he must have had solved the problem with recombining. Do LED`s solve this problem? can`t see any LED in his demo cell. I have tested with LED`s but that was for making more gas and i didn't see any improvement, but LED`s used to hold the gasses apart have i not tested yet. But i have found out that LED`s working on AC with up to double voltage...the light is pulsing a bit if you look close...don`t know how long they will last on AC.
    The closest to no voltage loss in a cell is with AC so far.
  10. haithar
    Hello Alan,
    i'd like to know how you connected the led to your cell.
    I would do it with a grid mesh of ss in the water, in series with a led to ground. how did you do it?
