Secret of Stan
Started by unknown · · 9 posts
copy from Russ's forum.
http://open-source-energy.org/forum/showthread.php?tid=1424&page=3
i said word "brown gas is powerful than hydrogen(h2)" then i try to figure it out,and what gas is more energy than hydrogen?
1.mass=18.042.dont know the name.
2.mass=1.hydrogen1,not h2.
search wiki,energy level.if atom has lowest energy level it will stable,that mean if it has more energy level then it don't stable and more powerful when ignite.
gas has highest energy level,much more than liquid or solid.lowerst energy level is solid.
atom has higher energy level than molecule.atom try to stable then it find another atom to make it to stable state(lower energy level)=molecule or covalent bond.
then you known the answer=H1.
if you ionize H1 to H1+ then it must powerful than normal H1.High voltage and gas processor,all this things to make it powerful than normal.Ionization it to highest energy level.
why stan use high pressure?gas atom when you compress it will be hot,this hot will go to h2-->h1=higher energy level and not stable same concept of air condition,to compress gas.
why liquid gasoline cant ignite?it can ignite when it is a vapor!!!why?higher energy level.
all best.
thanks
geenee -
So how do you create H1 from brownsgas, Geenee?
Or Rus?
Any good ideas?
Remember that brownsgas has only maximum of 3% H1.
Rest is H2.
i saw Stan told about buggy ,he said need more pressure to run a car.why?maybe hydrogen gas(h2)when compress h2 more enough(10-15psi).that can make h1.imho.i need more testings.
h1 is highest energy level like you said,why h1 is source of nuclear fusion. -
How are you going to test pressure, geenee?
Please do not try pressure on hho.
Only on H.
thanks Steve.i will be careful.
fixed some thoughts.
when pressure hho,atom will be decreased mass of gas(h2,o2) then energy level will be lower than normal gas(because release heat or energy out=compress gas,gas will release heat or energy to environment).
when decompress this gas,gas will cold because absorb energy from environment to go to normal energy level of gas(before compress).
when compress hho,it compress itself(free force).hho release energy to environment when compress it.then this energy can break bond of h2 to h1.
when decompress hho,it absorb energy from environment(capture free energy).before ignite it.you have 2 times of free energy to use and by product is h1.
Imho.just theory.but i will proof soon.
ref,
http://en.m.wikipedia.org/wiki/Binding_energy
http://www.pureenergyblog.com/2013/09/04/1780/8502375_freddy-posts-video-crown-victoria-running-on-100-water/
fast freddy release videos and talk about pressure.maybe this is the secret of Stan.
freddy just use low voltage - high amps electrolysis but he need more pressure,why??? he can sent it to engine without compress but he didn't do that.he need 20 psi or above.he talk about high pressure that make a gas more powerful or more energy.
and old video.fast freddy
Stan never showed varistors on his drawings,.. How did he limited the voltage to not burn expensive components?
Voltage can't burn component,Amps is.
Seb,let you try with 3055 and h1d11 replace mosfet.maybe work. -
My problem is not the gate.
I'm working with much higher rating than the 3055, it wouldn't be a choose for what i'm trying to accomplish.
Amps cam only flow if there is a voltage over the breakdown voltage of the component.
There are two ways of burning components, by over current of simple over voltage, over voltage will lead to current flow and that minimum will destroy the device, while amps can only burn components by over heat.
So voltage is dangerous than amps when the switch is open.
I just had an epiphany!
I was looking into a page and found that sidacs are called switching diode, because they only conduct after its rated voltage. It can work like a varistor, also there are other components that behave in that manner.
Would Meyer Use a SIDAC for the switching diode function?
What i'm doing is: i'm finding a way to let the field collapse while not burning my components and still send the voltage field to water and not to snubbing.
