Is this what Meyer was doing with the VIC?
    Meyers VIC is the same kind of transformer as this man is showing!
    Go have a good look!
  2. HMS-776
    I don't think so. An inductor (in this case the secondary coil) has an inductive reactance which is directly proportional to frequency. Notice how he increases the frequency from 200 to 950 Hz and when he connects the load at 950 Hz his primary power draw drops. This is due to the high secondary impedance (inductive reactance) being reflected back to the primary coil. It is not OU.
  3. HurstOlds
    Did you see @ 3:39, when he connected the primary coil....only one lead on the LED light bulb but it looks like it lit up a little....
    Is that pulling power from the air or whatever, kind of like an exciter circuit?
