HHO + atomize water fuel with Piezoelectric
Started by unknown · · 8 posts · last reply 25 May 2011
Hi guys,
I have a thread over at overunity on HHO production with piezoelectric.
http://www.overunity.com/index.php?topic=10388.msg278807#new
This process utilizes commonly available ceramic piezo transducer to atomize water into micrometer size particles with secondary stage ZnO crystals to produce HHO from surplus ultrasonic waves. This process is ultra efficient allowing closed loop operation of ICE engines on water as fuel only. Non electrolyte process and no modification to ICE other than upgrade to high performance spark plug.
If there is interest here, I will be happy to answer any question.
Thank you and have a nice day. -
Well my question is, how to?
Thanks -
Thank you for your interest. How?. By following disclosed procedure.
Water is dissociated at 43+ khz, aetheric bond is solidified or caused to compress releasing elements to seperate freely. ZnO oscillates to surplus waves resulting in electrification of water molecules and harmonic resonance amplifies HHO production.
Common submersible transducer is used, nebulizer circuit can be used with output voltage altered to achieve required frequency.
Key is atomizing chamber with receiver cells plated with ZnO allowing amplifications of interia motion, many geometries will works.
"My second discovery was of a physical truth of the greatest importance. As I have searched the entire scientific records in more than a half dozen languages for a long time without finding the least anticipation, I consider myself the original discoverer of this truth, which can be expressed by the statement: There is no energy in matter other than that received from the environment." — Nikola Tesla
Please replicate and post pictures, I will help where needed. -
well i would need more info.. if you can post here everything you found about it would be great. Thanks
sebs -
Hi Powe1,
Of course we are interested in new technology's in creating HHO.
You ask us to start replicating, but i havent seen any schematics, or material choices etc etc.
Please be more specific.
The 43khz is a frequency we have seen more often in the past.......
Do you suggest that you can break water just with sonic waves into H and O?
Hello,I am a beginner and my English is not good enough,but I need some advise in which direction is better to try:Meyer WFC+piezoultrasonic or Meyer WFC+Avramenco/Tesla single wire.And for this reason I ask from the experienced ones about what exactly to read because it is tones of information,would take a lot of time with unknown results.It is a comparation of results,productivity of different ways,setups to produce hydrogen ?
Or where and who to ask these questions ?
Thanks for understanding,
pmihai99 -
I think I must clarify what I mean with single wire:Modified VIC see the atachment.
I have a 50watt watlow piezotransducer glued on a rubber fiberglass which was used for water heating at 120v 50hz would this be good for 43+Khz ?attachment_8224 1wire.jpg
Welcome to ionIzationx!
Interesting mindwaves!
Have you tried such setup and did you produce any gas?
