Herman Anderson circuit proposal components
The flipflop oscillator could have been made by this first stage of an oscillator with a CD 4047 chip with flipflop gateways:
I.C CD4047 1p
Capacitor 0.01uF or 103 1p
Potentiometer 100K 1p
Resistor 220E 4p
Resistor 10K 2p
Resistor 330K 1p
LED RED 1p
The followed by a circuit that steers the SCR in the powerline to the anode.
See picture.
There must be an extra PNP transistor stage in front on that circuit from the pic, to make the scr switching at the same moment as the flipflip does.
The other output towards the 70kv coils will follow later....
In a later stage, i will add everything together to 1 circuit schematic for the ones not so well educated in electronics.
added: driver for ignition coil 70kv setup
TR1 Ignition Coil
T1 BFY51 Small Transistor
T2 = 4 pieces parallel 2n3055 Power Transistors
R1 100 Ohm Resistor
D1
1N4007 will do but preferably a Schottky Diode
RC1 0.1µF Capacitor + 10K Resistor
http://hackaday.com/2016/12/08/measuring-high-voltage-in-millimeters-and-other-hv-probe-tricks/
Steveattachment_14956 attachment_14963 attachment_14965 attachment_14967 attachment_14977 IC4047 basic configuration.png scr switching positive.png ignition_coil_driver_circuit_diagram_2.jpg sphere_length_voltage_chart.jpg 4047-astable-multivibrator-circuit.png
What kind of waveform can imagine if I said :
Between a sawtooth and square box ? -
The question is how the waveform will look like in the scope.
The circuit will produce first a square shape puls which might look like a bit diff with a charged cell attached.
The hv pulse after the squarewave will show a voltagepeak.
But again. Not sure how it looks in scope with cell. -
That's what I should have ask I guess is how you imagine a waveform would if I said:
Between a sawtooth and square box on your oscilloscope. -
I think this is what Herman ment...It's cited in all 3 of his patents and looks perfectly to his description.Flip Flop...Push pull what ever but you can tell it's not what was described at the end of the interview.It puts out an AC square wave at .
https://www.google.com/patents/US4820957
