Electrolysis
Please if you dont mind, you can help me start these areas of the forum by starting a topic or even making a new post here. These areas can be anything related to what the category is for. -
Came across a water purification device awhile ago that may have some supportive information relating to electrolysis and Oxygen.
It is called the Water D.O.G.
United States Patent 6,689,262
Inventor: Senkiw
February 10, 2004
Microbubbles of oxygen
Abstract
An oxygen emitter which is an electrolytic cell is disclosed. When the anode and cathode are separated by a critical distance, very small microbubbles and nanobubbles of oxygen are generated. The hydrogen forms bubbles at the cathode, which bubbles rise to the surface. The very small oxygen bubbles remain in suspension, forming a solution supersaturated in oxygen. The electrodes may be a metal or oxide of at least one metal selected from the group consisting of ruthenium, iridium, nickel, iron, rhodium, rhenium, cobalt, tungsten, manganese, tantalum, molybdenum, lead, titanium, platinum, palladium and osmium or oxides thereof. The electrodes may be formed into open grids or may be closed surfaces. The most preferred cathode is a stainless steel mesh. The most preferred mesh is a 1/16 inch grid. The most preferred anode is platinum and iridium oxide on a support. A preferred support is titanium. Models suitable for different uses are disclosed.
IndianaBoys
Water DOG Paten t6,689,262.pdf
Anybody been here]
