Cosmic engine - for water engine, orgone engine etc...
Started by unknown · date unknown · 10 posts
Hi everyone, now I have a model of the cosmic(planet, body) engine. If you look at it you see why Pantone had sucess with counter spinning vortices and why the water engine is an ion engine and why steam+HHO is necesssary. The neutral center is the heart of the engine(Keely) and chinese medicine is right, 12 internal force lines and 8 external lines(bows).
Have a look and if you have crystals at hand try to place them in the geometric pattern.attachment_5094 CSphere.GIF
Interesting stuff, Gauss
Thanks Steve, new drawing with more info on how to build will follow.
We have results from the first tests. Water stays charged positive with a 2D setup from the cosmic engine. About 10 seconds with a water glass on top of the 2D model is enough to charge up the water. Though the 2D model is a bit unbalanced since one centripetal force line lacks this is very, very good news. Next test will be with a 3D model. -
Amazing stuff!
Hey Gauss
Positive water ?
I heard orgone and + water can cure cancer , do post more info . -
Hi, please check this link:
http://www.ethericresearch.com/forum/viewtopic.php?f=38&t=57&sid=0668017734459ef94ba32b86c3ecfc95
I am in a bit of a hurry, I will post more info when I get back in 2 weeks.
I have some more news, we have charged incoming plant water for a large cucumber greenhouse. After 10 days the whole energy inside the greenhouse is changed and it seems like the plants have alot more "subjects" than usual and grow better. In 10 days we will know more exactly how much more.
In other news we made a new device including wooden shavings, very promising results and a more subtle energy, less aggressive and gives better taste to water. -
I have also given some magnetic water to plants , and had my mother give a blessing .
They seem to like it
. Couple day and all healthy and lively .
I am gonna test out this new modulator ive been tinkering on .
Healthy resonance for my water , Puharich style , 60 hz is not good . I was thinking 8hz modulated onto a 528 carrier with my magnet mixer , it can be totally re-invented .
We should talk Gauss . -
HI!
I have a new 2D model....
This one is by far the best one we have built, the power is a magnitude higher than the other ones and geometry is the reason. This one has three Domus(8 symbol) placed out symmetrically around a circle. That means an oval every 60 degrees. I will try to upload some pics later. Now we will try to merge one triple Domus, one dual Domus and one single Domus into a complete 3D model. I believe
in the three spinning shells you could say... More news next week when finished about that one...
This one has two centripetal force lines and one centrifugal force so the natural balance is acheived where the former dual Domus models had one to one ratio, so the negative(centrifugal) was too big.
Still the cucumbers are growing very very fast...
Dankie, you could always send me a PM...
