Complete VIC Circuit- but couldnt work? :(
Started by unknown · date unknown · 11 posts
Hi everyone,
I have a problem. please help me. I download and built from www.globalkast.com , by tony woodside, Complete VIC Circuit . Everything is ok , I use 12 volt but it couldn't work. Where am I is wrong. I havent make any adjust. I added some pictures . only two leds lighting . Also I couldnt get any square wave in oscilloscop
. is there anyone to help me ?
Thanksattachment_13885 attachment_13887 attachment_13889 attachment_13891 stan 1.JPG stan 2.JPG stan 3.JPG stan4.JPG
Hi everyone,
Thanks
Hi everyone,
Thanks
Dear Hgul,
Thanks for showing yr setup.
For years now people are trying to replicate Stans work.
But no succes yet.
Did you ask Tony for help?
Thanks for your answer Steve. yes I asked and mailed to Tony , and waiting for answer.
Maybe we can help if you make a schematic of your setup.
How does yr VIC looks like?
How many turns per coil, wire thickness and winding directions, etc etc?
I seen on Tony,s documents that he had some ideas of his own, which where not the real vic setup of Meyer.
cheers -
thanks for your help Steve. I usede Tony circuit from his website
http://www.globalkast.com/documentation.htm
http://www.globalkast.com/docs/VIC_Circuit_Production_Eagle-5.10.0_Files.zip
I make all of them how written in schematic . working on nearly 2,5 months
If i remember correctly, the two choke and their connections are not hooked up well.
All coils must be wind in the same direction as well.
My 2 cents is to start slowly with 2 volts on the primary, see if you can find resonance and then tune up.
Also use a 70 ohm resistor over the primary...
For now that what i know... -
Hello Steve,
im doing many tests too here.. no results...
i think theres something on the winding of the chokes that can makes its resonant frequency lower somehow.. mine are resonating at 30khz or so.. i used insulation between each layer...
i get the step charging i guess... but no bubbles at all...
Welcome hgul keep strong.. its kind of a hard way to get it done... i think you better get the cell like meyer or steve did and start testing.. .it simply wont come out of of nothing! Believe-me... we are into this since many years.. .
if we can help you in anyway let us know.... as steve said try show the schematics of your coils..
Good luck! -
Thanks for your answer and couraging me sebosfato
I read Tonys message on this forum and use his pcb from his site . also I asked him is it ok. maybe I make some mistake while structred parts of circuit.
anyway no problem. I am studying and reading about stanley meyer,
hi friends Steve and Sebosfato
Is there any users or install manual about Tony woodside pcb circuit. Do you know ?
I mean after instructed circuit like Tonys make, what must we do for perfect work circuit? is there any document about this? do you know ? Thanks so much -
Hi everyone,
Thanks
You should certainly watch Valentin Petkov's videos. He has shown it working and his testing as well with details and references to patents. https://www.youtube.com/@valyonpz/videos
You also need to consider:
1. Your metal tubes in your cell will need to be approximately 14mm apart.
2. Charging choke will need to be tuned for your cell.
3. The resonant frequency will need to be dialed in with an oscilloscope
3. This frequency will change as the water breaks down. Thus why Stan created the PLL circuit and scanning circuit to dial in on it.
Hope this helps!
