Alternate Energy Devices Of The Past
    Many years ago, there was page article in alternate energy magazine with drawing of spiral vortex dual 110v AC transformers that would provide higher wattage on output. (You know about the tornado effect) The unit was tested on refrigerator with proper meters and power factor. Also the best wind mill generator design was the US Patented "Tornado Turbine"
    , Also the late Mr. Baumgartner demonstrated a simple hover plywood platform lifting effect with small wattage train motor rewired in series for speed, and vortex spinning vanes. He had used computer program to design the natural log spiral for control of the ETHER. It was shown lifting him in a room and then later, the front end of the city bus. Why can't anything be purchased?
     Alexander US Patent 3913004 1975 --
    The technique of rotation with transformer effect (double wires on rotor) as in the above Patent method to increase energy, allowed inventor to make self running car with 4 air motors at wheels with air tank, battery , alternator, and modified military motor/generator with excessive output torque free energy to run main air compressor.
     The Stan Meyer Patented ionized Hydrogen gas H+H+O-- generator is way over unity (not electrolysis) and usable, since the Patents time has ran out. He drove around his modified VW engine on dune buggy. That third level system was water injectors type with electrical controller. - More complicated than the earlier, usable, large water cell type that contained circular SS pipes.in distilled  water, for Voltrolosis.
     In 1980's New York there was a self running air compressor with no battery or motor. The main shaft had journal with air cylinder that had higher pressure coming from inherent vortex tube higher pressure than 40lb tank + insulated heat chamber. Unit had spoked, balanced, heavy rim steel flywheel. Flywheel was hand turned, then released at 40lbs in tank. The Vortex Tube had 3 machined parts from 3 separate work machine shops, so as final design as put together would not be known. Inventor was mowing lawn outside trailer with long air hose hooked to tank. The interested Company reneged on the $3 million dollars wanted after 1 year. I saw this unit myself way back when. The retired elderly carpenter in the trailer complex in Bath N.Y., was legally changing ownership of system to his son. He was also ordering replacement, better quality bearings.  The Democrat newspaper had an article on him.
     John W. Keely had shown demonstrations in 1890's Phil. Pa, of lifting effect (no gravity) with resonance frequencies and harmonic ratios using array of tuning forks and multiplication of higher vibrations on heavy metal spheres .His "transmitter wires" of gold, platinum + silver, are now called thermocouples and thermopiles. Witnessed by engineers, newspaper men, and investors at that time. Tesla didn't like Keely since Keely got more investor's money than he did.
    S1R9A9M9 (Nathren) of 2008 videos showed Briggs 18HP mower engine self running overunity with electrolyte water in carburetor. Hydrogen gas electrolysis at spark plug with also water vapor pressure generated same time at neg 34 degrees ATDC. Magnetic field coil - called triple coils assy, over plug wire extends firing time for more contact with water. EGR improves performance. Alternator under flywheel provides constant 10 amps after battery was disconnected. Web site shut down. Special vacuumed sealed dual 1.75MH coils relay per cylinder also used for time spark extension. His 1978 V8 El Camino tooled around town at 18 MPG water, until locked up in a security garage.
    You don't know about specialized information because you want data dropped in your lap, rather than doing your own science research yourself and finding out what others have already done. Back issues of alternate energies magazines, documents you have to purchase, and published data on Internet YOU have to search for. See DVD VHS movies The Water Engine and 1949 Free For All .
  2. russrHHO
     Unusual Alternate Energy Designs Noted From The Past
    Information has been provided for the ONLY purpose to enlighten others of data they may have missed over time, and may be interested in looking into them further. A Vortex Tube use of hot air end can greatly increase air PRESSURE in insulated chamber going to a air extension cylinder , to keep a shaft turning with balanced spoked flywheel. Lots of devices are made and shown that don't make it to public market. There are over 100 US Patents on just one subject matter of water saving techniques for our common toilet tank. (A free plastic jug of water takes up the space in back of toilet tank when placed inside, no money expended) You have the perfect right to not believe in over unity - greater than 100% efficiency, or methodologies that greatly improve use of a standard technology design. The word invention means something not seen or heard of before that everyone else has NO reference to, and therefore don't believe it. The Engineering Degree on wall plaque is based on dated earlier known facts to be taught forward in time without improvements.The other term is - N I H, not invented here. Firm down the street adds parts that greatly increases efficiency of their motor design. The longer standing, similar other firm manufacturer of motors wants to keep their own design the same as being less efficient and continue selling it. They completely refuse to pay $$$Royalty fees to implement that new circuit to the existing selling motors. Mr. Zubris filed US Patent on capacitor circuit that greatly extends miles range of electric cars. He sells personal use of circuit for home made electric car or motorcycle for $100. The car manufacturers refuses his design. N I H
    Nathren, as part of group of technicians in 2008 Georgia developing the engine spark plug electrolysis to Hydrogen fuel technology had been put in jail years back. I doubt it had to do with improper computer downloads. Another technician who converted is car to run on Nitrogen Hydroxide and Hydrogen gas had died in prison. False claims of murder were applied. Dan Danforth of Sri lanka technician disappeared after his public demonstration of car running on high efficient Hydrogen Generator. Stan Meyer of the over unity Voltrolisis hydrogen Generator cell was poisoned at restaurant , etc. Meyer Process was at 3 levels for Hydrogen Generator. Why can't you study the first level called,- Proof Of Design" before making negative comments. The Patents are in public domain. You can do a 1st level bench test for your self. (Extremely fine upward flowing gas bubbles to foam with low low current and HIGH VOLTAGE)      Seek And Ye Shall Find.
