the nitrogen discussion
Started by unknown · · 6 posts · last reply 26 February 2014
    Have a look at this old document.
    On page 361 its clear that nascient hydrogen bonds with nitrogen.
    This makes ammonia. Ammonia is solvable in water.........
    Burning water.
    Fuel
    injector
    Meyer
     The collected works of Sir Humphry Davy ...: Discourses delivered before the Royal society. Elements of agricultural chemistry, pt. I.pdf
  2. geon
    ammonia is hydrolized in water
    NH3+H2O <=> NH4+ + OH-
    http://en.wikipedia.org/wiki/Haber_process
    ammonia isnt easy to make maybe inside engine with high pressure?? don't know
  3. geon
    the thing is that nitrogen sources and water form NOx oxides with form HNO3 which turn most balanced equations that make nitrogen compounds to the wrong side because of le chattelier principle.. this ammonia synthesis is quite hard...
    Yes. But i am very curious if this might work.
    Electrolysed hydrogen atoms bonding with nitrogen or carbons....
    If that can work in the waterbath....
  5. geon
    you can make ammonia straight in an electrolysis cell or other nitrogen compounds
    The method of claim 1 wherein ammonia is produced via the reaction of a nitrogen source fed to the cathode side and a hydrogen equivalent source such as carbon monoxide or a mixture of carbon monoxide and hydrogen rather than high-purity hydrogen
  6. geon
    other research uses nafion membranes and alloy catalysts to make the electrolysis cell so it's expensive..
