Is the VIC 6-1 amplitude controller for the bifilar ?
Started by unknown · date unknown · 7 posts
  1. Dankie
    Somebody told me me that the VIC 6-1 might actually be the the "amplitude control circuit" for this bifilar circuit . It would be great to see with a phase meter , if there is actually some current phasing going on with John's connection as the frequency is changing, I believe there is not , so I wonder if this is not just some advanced form of power supply .
    It is true that the waveform is the same but that waveform will always be the same when you have capacitance in the circuit , its nothing telling at all .
    Also I wonder why go through so much trouble when a normal rectified transformer would do the same thing , perhaps a question of efficiency ?
    But then theres also the issue of how it is you should connect the VIC 6-1 to this bifilar , it all makes no sense , the bifilar is grounded but is also connected to the 6-1...
    Also , Kinesis , plz confirm that you are indeed getting some unipolar pulses with no other diode besides the one before the positive red choke and inputing unipolar pulsed dc on primary side.
    attachment_3694 attachment_3702 attachment_3706 attachment_3708 familiaroscope-0000000.jpg bifilarr.JPG bifilarr.JPG bifilarr.JPG
  2. kinesisfilms
    dankie it is not....it is completely seperate......6-1 is not variable voltage control i can show you with my scope what happens if you put a normal 50 percent duty square wave into it without the correct proportion of amplitude to power.
    and the only diode i am using is the one on john's cil...aka the ONLY DIODE IN THE VIC CIRCUIT.
  3. Dankie
    How can you be sure ?
    Your scope shows me that your transformer is working in a unipolar way .
    but If your connection has no current phase , it will be hard for you to reach any sort of resonance , that is why I say you must test with a phase meter to see what is happening when you are switching those freqs
    Now if you cant reach resonance theres a problem , it means this isnt a VIC , and this amplitude theory is out of the blue , theres a problem ... Amplitude should be independant , its not working with lower voltage or higher voltage  ? Is that nice waveform frequency dependant ?
    Now is there a voltage rise @ a specific frequency ? I understand there is not ...
    Are you pulsing this with your frequency generator straight up ? You need a power source dude , full 12 volts from a battery with only the primary resistance and mayeb a tiny bit more , thats it  .
  4. kinesisfilms
    dankie i drew it out for you before NO I AM NOT USING JUST MY FUNCTION GENERATOR!
    LISTEN AND READ.
    damnit.....it doesn't matter what i write you completely don't even read it.
    do you know anything about electronics?
    look at my new topic called variable voltage amplitude control.
    i drew it out of exactly what is going on and what im doing......i even provided the wave forms at each point AND I HAVE EXACTLY WHAT IT SHOWS IN THE PATENT AT EACH STEP.
    holy shit.
  5. Dankie
    Yes it does look like the same waveform , but it is not doubled either and doesnt tell me much if this is really working .
    You say its working , I say lets check the other caracteristics we should see like voltage rise @ a certain frequency and input amps going down . , thats why I ask other questions .
    When you say "it works" , plz elaborate .
  6. kinesisfilms
    it means that when the 50% duty cycle on pulse charges up the inductor and then on the off pulse the inductor releases an exact equal pulse.....hence unipolar double pulses.
    even 2curiouswfc didn't ahve a good double pulse.....these double pulses are 1kv with a 5 volt amplitude input.
  7. Dankie
    Well it may be that you are right .
    VIC coil 6-1 is not like a regular coil , its a pancake coil bifilar and wrapped with a transformer . It may just work like you say it works .
    W/e way you choose it will be high-volts low amps .
